 Rudder Drag
Mark Maxwell
Initially Posted - 10/10/2001 :  12:49:56  Show Profile
I've been following the post about the new balanced rudder and that it may cause more drag than the older style. I may be wrong but the way I see it is that rudder drag is the effect of the blade being moved to create low pressure on one side and high pre
Douglas
Response Posted - 10/10/2001 :  22:14:19  Show Profile  Visit Douglas's Homepage
Might be true on an aircraft but not a boat. Not enough to notice anyway. When you turn the rudder to one side its not lift or lack off that turns the boat its sheer water pressure on the side of the rudder and the direction the water i deflected to.
eric.werkowitz
Response Posted - 10/11/2001 :  00:09:35  Show Profile
Douglas,
We've had this debate in the past without resolution. But, if no lift is generated in water, why do boat builders waste time, effort, and rudder strength by fashioning them with a foil design instead of a flat, round-edged slab?
Eric Werko
n/a
deleted
Response Posted - 10/11/2001 :  11:19:53  Show Profile
Eric,
Good question. Is there a marine engineer out there who can give us a quick dissertation on the subject?
George Seaborn #1190
Douglas
Response Posted - 10/11/2001 :  13:30:07  Show Profile  Visit Douglas's Homepage
1) It wouldn't look good if it was shaped like a door.
2)Yes there is some drag that is eliminated but unless you are racing and realy into the big buck racing it doesn't make a lot of diferance.
3)I am in Aviation and for something that small to gener
Dave Seely
Response Posted - 10/11/2001 :  14:12:15  Show Profile
I'm not a marine engineer but I am a mechanical engineer with some fluid flow experience and I think I can explain a few thinks.
Whether a rudder is balanced or not has nothing directly to do with drag. A foil (the rudder in this case) using a NACA00 p
Brian G Smith
Response Posted - 10/11/2001 :  19:26:10  Show Profile  Visit Brian G Smith's Homepage
Having owned the 1980 rudder and then built a balanced rudder for the C25 I can attest to its qualities. The balanced rudder places the leading edge forward where it should have been to begin with. Hence not only is the rudder more balanced on its pivot i
eric.werkowitz
Response Posted - 10/11/2001 :  22:44:17  Show Profile
To Douglas and Dave,
You both mentioned that a rudder foil is symetric and that the symetry differentiates it from an aircraft wing in regards to lift. The implication being that the air flowing over both sides goes the same distance and, therefore,
Dave Seely
Response Posted - 10/12/2001 :  09:08:13  Show Profile
Your argument about the flow paths being different lengths is correct but would you call this lift from the profile of the foil or would you say that it creates lift due to the angle of attack more efficiently than a thin flat plate? Your argument could a
Response Posted - 10/12/2001 :  18:33:33  Show Profile
When comparing fluid dynamics... there is considerable differance between the effects of water and air. A good example of this is the effort required to balance the helm. While considerable adjustment is needed on the sails, mast rake, etc. (which have
eric.werkowitz
Response Posted - 10/12/2001 :  19:28:39  Show Profile
Dave,
In re to your question about the 2x12 with a rounded nose, I would say the thick trailing edge would add some uncertainty (and turbulence) to the path lengths. The result would be what Arlyn notes as a poor lift to drag ratio.
I believe the r
Dave Seely
Response Posted - 10/13/2001 :  22:20:54  Show Profile
Eric, Actully its called Magnus lift. Corriolis force or the corriolis effect has to do with the trajectry of objects within a spinning refferance frame. Try www.howstuffworks.com/airplane4.htm for an explination of magnus lift. I shouldn't have even bro
eric.werkowitz
Response Posted - 10/14/2001 :  14:24:25  Show Profile
Dave,
Yeah, Magnus effect. Some company was trying to build an airship that used the Magnus effect to controll it lift without using ballast. Don't think they made it.
In re to rest of thread, I've exhausted my knowledge (probably some time ago)
