 Gray Water Tank,-Does it need a vent?
existentialsailor
Initially Posted - 04/04/2006 :  20:49:23  Show Profile
I've removed my thru hull for my sink and am installing a gray water tank, does such a tank need a vent like the head tank?
Thanks.
Rick
Edited by - existentialsailor on 04/05/2006 04:43:06
takokichi
Response Posted - 04/04/2006 :  21:04:27  Show Profile
Rick - If you haven't closed the hole up, I'd put a thru hull and seacock in and skip the tank. Why do you prefer the tank route?
If you do put in a tank, you need vent. Otherwise as the water level in the tank rises, the tank will become pressurized and will not accept more water.
existentialsailor
Response Posted - 04/05/2006 :  04:45:44  Show Profile
I plan to visit some no discharge areas in the future and since the thru hull was weeping, I thought this was the opportunity to make the change. Thanks for the answer, I wasn't sure if the drain acted as its own vent or not.
takokichi
Response Posted - 04/05/2006 :  08:01:04  Show Profile
If you need to go no discharge in the future, you could just close the seacock and stick the hose in a gallon milk jug. When Casco Bay goes "no discharge" it will apply to black water only, not gray water.
