 Mast raising system ...
Buzz Maring
Initially Posted - 05/26/2002 :  16:24:49  Show Profile
Hi all,
I have been looking through my sailboat folders and the tech tips, but I can't find what I'm looking for. 'Seems to me that someone invented a mast raising system that uses an "A-frame" made of conduit ... the apex of the A-frame attaches to the end of the forestay, the two feet attach to the deck, and the mast is pulled forward into the raised position using a winch, blocks, or whatever to give you a mechanical advantage.
I don't think I dreamed it, and I know it's NOT the "Huntington Rig" ... I've got plenty of info on that.
Does anyone know where I can find information about this gizmo?
Thanks!
Buzz Maring
Response Posted - 05/26/2002 :  18:52:00  Show Profile
'Found it! Here is the link for anyone interested:
http://c25c250.best.vwh.net/restricted/bearsad1.html
There are several ideas on this same page ... scroll all the way down the bottom to see the A-frame mast-raising idea.
This looks pretty slick to me ... has anyone ever tried it?
gfrazzle
Response Posted - 05/26/2002 :  19:10:30  Show Profile
Hi Buzz,
I just built the A-Frame a couple of weeks ago and it works well. I dropped the mast by myself using the system- a lot of work but doable. I haven't used it to raise the mast yet- the boat is still in maintenance. I built the stern mast crutch out of schedule 40 PVC with a mount on top for a trailer roller to roll the mast to the stern when ready to hoist. I'm anxious to try it out. The key is to take the time to ensure all lines/ shrouds/ turnbuckles/ stays are in the correct position prior to beginning the hoist/ drop.
Total cost for the whole system was less than $20.
Flyaway Hull# 1743
Buzz Maring
Response Posted - 05/26/2002 :  20:06:11  Show Profile
Do you have a photo? I was thinking about doing the same thing. In fact, I was considering using concentric PVC pipes so that I could raise the mast a bit on the stern before trying to winch it all the way up ... my idea was to drill some holes through the outer pipe and use a pin to hold the inner at successively higher levels ... kinda' like an adjustable crutch.
Also, what sort of conduit did you use? A friend of mine told me about "rigid" conduit ... it is supposed to be stronger than the usual conduit. I was thinking about using that for the A-frame if it isn't too heavy or too expensive.
Thanks for the help and encouragement ... I really appreciate it.
MattL
Response Posted - 05/27/2002 :  02:38:46  Show Profile
With the help of my neighbor and his wire welder I (he) built a mast crutch similar to the one in the catalina direct catalogue. I used it to raise my mast a few weeks ago. I did that with the aid of a guy that just got his motor boat on a trailer. For the two tubes I used 1" square tubing that fit into 1.25" square tubing. We made a roller to fit on the end and it extends from the top of the rear pulpit to about 7' up from there.
It worked well except there seems to be a lot of flexing in it when pushing the mast back, I think a couple of lines leading to the jiib cleats would help. Also I have a little room between the sides of the roller assembly and the roller that caused lines to get caught as it was being pushed back. The flex caused concern, I think it will work much better with extra support. Seeing the flex I got I would be very leary of using PVC pipe. I could see it snapping very easily. Since I was so concerned about the bending of my assembly I was trying to hold that while lifitng the mast and I think this made it more difficult. For extra lifting power I used the main halyard attached to the bow and the halyard wench. This worked well
Matt Loeffler
E.C. Rider
Cat 25 86'
FK/SR _/)
Buzz Maring
Response Posted - 05/27/2002 :  10:39:03  Show Profile
Thanks Matt ... I was considering the heavy duty PVC 4" with 3" inside, but that might not be strong enough ... back to the drawing board.
