 What's that banging? Loose Keel?
chokenpoke
Initially Posted - 04/13/2006 :  15:47:39  Show Profile
Took my 250 out on her first overnighter and anchored in the river under relatively calm conditions. Every time a wave came I'd hear a loud "thud" all into the night. This was a constant problem that left me pulling my hair out trying to figure out what the hell it was. The sound was so loud and deep that the only thing I could think of was that the keel was loose and wiggling back and forth. I tried raising and lowering the keel, but nothing helped. Has anyone had this problem before? Can anyone think of what this may be? I can't sleep on my boat with this constant racket. Please help.
Tom Potter
Response Posted - 04/13/2006 :  16:04:33  Show Profile
Welcome aboard Nick.
Since I have a wing keel, I have no moving parts down below so I can't give you much help. I once owned a swing keel Macgregor and it to made the thump noise. That's one of the reasons I went with a fixed keel this time. There are others on the forum that have the WB models and have the same problem. Here's some [url="http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=11971&SearchTerms=keel"]discussions[/url] on that subject.
Edited by - Tom Potter on 04/13/2006 16:06:10
chokenpoke
Response Posted - 04/13/2006 :  18:57:08  Show Profile
Thanks Tom!
Response Posted - 04/13/2006 :  21:44:48  Show Profile  Visit britinusa's Homepage
It's the classic keel thump!
We have been putting up with it since we first got the boat.
Always staying overnite as we trail the boat every trip, we have experienced the banging keel every time there is any kind of water movement.
Turns out our keel is missing the washers between the keel and the keel keeper (for want of a better term)
Catalina is sending us new items next week.
Check your keel for sideways movement. I was amazed at the range of lateral movement, but even a small move will cause the bangs!
chokenpoke
Response Posted - 04/20/2006 :  13:59:53  Show Profile
So I asked my dad the "engineer" about this problem, and he made an interesting suggestion. His idea was to wedge a "noodle" (the foam pool toys that you float on or use to whack people on the head) between the keel and the boat. He wants to string a rope through the noodle and submerge it behind the boat while at anchor. With the keel down, I would then walk the rope forward (with each end of the rope coming up from each side of the boat) until it is stopped by the keel. Then I would simply raise the keel until it is snug against the noodle, effectively jamming that piece of foam in there. Any thoughts? Am I a moron for thinking this will work?
Russ.Johnson
Commodore
Response Posted - 04/20/2006 :  15:38:25  Show Profile
Chokenpoke,
I'm interested in this problem. What's your hull number?
Both myself (hull 793) and Paul (hull 841) had similar problems.
In my case, the centerboard was broken and the sleeve needed to be re-attached.
If you can put your boat on the trailer, it's a pretty easy inspection.
If your centerboard was damaged like mine, the problem will only get worse.
On the other hand, it might be as simple as installing plastic shims.
Here's a link to the problem with my boat --> [url="http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=11971"]Centerboard Noise - More Than Shims[/url]
The pool noodle is a good idea, but I would verify you don't have a serious problem first.
Let me know what you find.
Russ (#793)
Response Posted - 04/20/2006 :  21:23:51  Show Profile  Visit britinusa's Homepage
We actually thought of doing something similar to the noodle trick.
Keelhauling the guy that left out the spacer washers!
