 Fiberglass Care
amc93t
Initially Posted - 06/02/2002 :  12:55:57  Show Profile
I have now owned my 84 C25 for about a year and am now starting more tinkering in addition to sailing. One thing I notice when cleaning the hull and deck is the white runoff from fiberglass (dirt or oxidation I'm not sure). How can I treat my boat to slow this white precipitation and possibly help maintain it's surface appearance.
AMC93 on Giddy-Up
Response Posted - 06/02/2002 :  20:00:28  Show Profile
Welcome, amc...
There're lots of possibilities that depend somewhat on the severety. If you get a lot of white powder on your finger when you simply run it across the fiberglass, you should start with a fine grade of rubbing compound, and then move on to the next series of possibilities--where I'll mention two that have worked best for me:
- 3M Fiberglass Restorer-Wax is one of the best--a fine abrasive that goes on like car-cleaner-wax, with some rubbing, and then wipes off to a shine. I advise a power tool to do the rubbing--there's a lot of it!
- Polygo, a liquid coating that is applied in multiple thin coats (I just did 6) with a chamois-type applicator you can put on a pole like a sponge mop. Keep applying until it doesn't look streaky. Each side of the boat takes maybe an hour, and the result I just got is spectacular! It looks like a new Catalina with a coat of wax. Others have said it holds up very well--we'll see. Don't put it on over heavy oxidation--the kit comes with its own cleaner concentrate and scrubber to take off old wax and mild oxidation. If you have a colored hull, Polyglow may be a questionable option--it'll put a shine on whatever faded, streaked colors (or marks) you have. <img src=icon_smile_shock.gif border=0 align=middle>
Watch what you use on your non-skid areas--cleaners can be a bear to get out of the grooves, and some things will make it too slippery.
Good luck!
Dave Seely
Response Posted - 06/03/2002 :  13:05:19  Show Profile
I don't know how bad you gelcoat is but mine was very badly oxidized. I started with the white rubbing compound ( fine) but it had no effect. I then tried the red rubbing compound which is much courser but it wasn't much better, infact the gelcoat was so porous that I couldn't get the red color off no matter how much I scrubbed. The next thing I tried was the green 3M abrasive pads. They removed the oxidization but I had to go back and compound out the scratches from the green pads. I found a grey 3M pad that was less agressive than the green and as Goldielocks said " it was juuuust right". It still requires that you compound out small scratched but it is less work than compounding behind the green pads. On the nonskid areas I used the pad first then the course compound with a stiff brisle brush. Good luck, I'm still working on mine, started almost a year ago.
joshuaheard
Response Posted - 06/03/2002 :  19:06:31  Show Profile  Visit joshuaheard's Homepage
I use a dry deck brush removed from the handle to get dried rubbing compound and wax from the rough non-skid areas.
Douglas
Response Posted - 06/03/2002 :  19:36:02  Show Profile  Visit Douglas's Homepage
BonAmie and 400 then 600 grit wet/dry sandpaper wet.Follow with 3M fiberglass restorer/wax.
Doug&Ruth
Wind Lass
Tacoma Wa.
gfrazzle
Response Posted - 06/05/2002 :  02:48:19  Show Profile
I just finished the hull on my boat which had been neglected for longer than I care to admit. I started with a palm sander and 600 grit sandpaper, followed by a buffer with 3M super duty rubbing compound. The hull looks new again.
I just use Softscrub/ cleaner on the topsides/ deck- it gets chalky again quickly in the California sun anyway and wax just makes it slippery.
Flyaway Hull# 1743
Response Posted - 06/05/2002 :  09:12:18  Show Profile
AMC93,
See my recent and longwinded post under the "Gelocoat Restoration" thread. I also only use Soft Scrub with a Scotch Brite pad on the deck and cabin.
