 Genoa Sheet Rigging Hangup
sanibelle
Initially Posted - 05/31/2006 :  16:28:14  Show Profile
Hi Guys,
Quite often, the sheet bowline knots hangup on the forward lower shrouds when I tack. I've been thinking of running these shrouds through 1" dia PVC tubes. Would there be any problem unfastening the the shrouds (one at a time) to do this without otherwise supporting the mast? Or might there even be a better solution.
Is this a common problem?
Thanks for any input.
Joe (1980 TR/FK)
Response Posted - 05/31/2006 :  16:42:06  Show Profile  Visit Frank Hopper's Homepage
No problem. Take enough time to add the rollers AND retune your rig.
John G-
Response Posted - 05/31/2006 :  17:54:57  Show Profile  Visit John G-'s Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by sanibelle</i>
<br />Hi Guys,
Joe (1980 TR/FK)
<font size="2"> <font face="Comic Sans MS">
Joe,
There are shroud covers that will help bring your sheets around. You will have to see how high up your sheets are fowling and have covers go at least that high up.
My problem with the covers is twofold.
One, when you have to go forward in a blow or choppy seas you will grab the shrouds, we all do it, and the rollers will....roll. Not safe.
Two, any cover on the shrouds has a tendency to trap water near or on the shrouds. IMO it’s best to leave them uncovered to air dry.
Since you say the “sheet bowline knot<b>s</b>” hang up I am going to assume you use two sheets tied on to the clew.
Another approach is to minimize the knots that will get hung up.
Try one continuous sheet that has a [url="http://www.westmarine.com/webapp/wcs/stores/servlet/product/10001/-1/10001/4101/10001/324/323/2"]snap shackle [/url]tied in the middle so there is only one knot, I use a simple overhand and it flows through quite easily. Also try to time your trimming when the knot has cleared the shrouds.
Good luck.
Underlined words are a <b><font color="red">HOT</font id="red"></b> link.
</font id="size2"> </font id="Comic Sans MS">
Response Posted - 05/31/2006 :  18:17:10  Show Profile
Since I don't change headsails (furling), my continuous line genoa sheet is tied directly to the clew with a simple Cow Hitch/Lark's Head knot which has never budged nor hung up on the shrouds.
John G-
Response Posted - 05/31/2006 :  18:30:33  Show Profile  Visit John G-'s Homepage
<br />Since I don't change headsails (furling), my continuous line genoa sheet is tied directly to the clew with a simple Cow Hitch/Lark's Head knot which has never budged nor hung up on the shrouds.
Dons solution with a [url="http://www.scoutxing.com/knots/larks_head/larks_head.htm"]Lark's head knot [/url]is even more fluid.
I only use a shackle because I remove the continuous sheet and tie the furling headsail at the clew with a 1/4" line when not in use.
Being 5'7" I can just reach the clew when the headsail is rolled up. Sun is the enemy of sheets.
Edited by - John G- on 05/31/2006 18:31:48
Mark Maxwell
Response Posted - 05/31/2006 :  18:41:14  Show Profile
I found that changing my tacking technique corrected most of the hang-ups. If you fall off enough to allow the heads'l to cross on it's own set your main and then tension the jib sheet it works very smooth. If my crew tries to pull the heads'l over with the sheet too soon it hangs. I have pvc rollers just like you mentioned and the knot can and does still hang-up. The delayed set works well. Just my $.02
Response Posted - 05/31/2006 :  19:15:04  Show Profile  Visit Champipple's Homepage
Mark's method will work, however if you wait until your jib is backwinded before releasing the jib, you will get the same effect without losing point. Not a big deal if your not racing, but if you are those 4 lost boatlengths will come back to bite you.
crcalhoon
Response Posted - 05/31/2006 :  21:49:16  Show Profile
This month's Good Old Boat has an article on rigging jib sheets with various rope knots to avoid the flogging stainless steel tooth-buster shackle. Coincidentally, I found that pursuant to some instructions I think I found on this web site, I rigged something called a Dutch toggle about a month ago. So far it works great and is the best solution I have yet found for the situation. Now that I've said that, watch the silly thing blow off next week.
Brooke Willson
Response Posted - 06/01/2006 :  11:12:51  Show Profile
I was writing a response yesterday pretty identical to Duane's -- but he said it better (as usual). When I changed my tacking technique to wait until the jib was backwinded so the wind would push the bow into the new tack, it was as though the clouds had parted. I haven't had a sheet hang up on a shroud since -- regardless of knot or hardware. It's amazing what happens when we let nature do the work instead of us forcing the issue.
Brooke
Edited by - Brooke Willson on 06/01/2006 12:29:31
RiverRat
Response Posted - 06/01/2006 :  11:21:35  Show Profile
Try a cows hitch with a continuos line.
PZell
Response Posted - 06/01/2006 :  12:58:47  Show Profile
I use rollers as discribed on the forward lowers and connect the sheets with buntline hitches which are more compact. Covering a portion of those lowers with the PVC doesn't appreciably deteriorate the shroud over its useful livetime of 5 years or so in my opinion. If it was closely covered as seen in lifelines then some concern would be warranted. Also I often use the backwind style of tacking the jib. I have several hank on jibs so change up or down as necessary.
Response Posted - 06/01/2006 :  13:21:55  Show Profile
My cow hitch can hang up, although as discussed, waiting helps. I'm considering going to a single-braid line for the jib sheets (for ease of handling) thereby making a somewhat smaller, softer cow hitch.
Response Posted - 06/01/2006 :  15:19:21  Show Profile  Visit Frank Hopper's Homepage
And never pass up a chance to retune your rig.
Stu Jackson C34
Response Posted - 06/05/2006 :  12:42:02  Show Profile
The buntline hitch is also recommended by some to replace the larger bowlines.
sanibelle
Response Posted - 06/05/2006 :  13:57:43  Show Profile
Thanks for all the useful info. Little did I know when I bought the boat that the cow hitch would be a deterrent to jamming. I actually cut the existing continuous sheet in half to achieve what I have now.
Joe (1980 TR/FK)
Heartbeat
Response Posted - 06/05/2006 :  17:57:46  Show Profile
Just curious about what size sheets you are using?
I have used both 5/16", 3/8", and 7/16 sheets. Seems like the 5/16" with a bowline don't hang up as much as the old ones. I run the bowlines a touch large in case I need to use a jib pole on a reach - that might help as well. Of course, I tend to run big sails, so most of the work may be getting the sail across.
I still have the larger sheets, but my 5/16" are (half season used) Laser main sheets I got from a Laser racer pal. The line is still reasible for handling, I think. At 42' they are a touch long, but my thicker ones were a touch short for going over the spinnaker pole with the 155% on deck. One day I'll figure out the perfect length and cut them down - maybe this season.
-Matt Q in Detroit
