While doing my annual bottom prep before the bottom paint,I've noticed some large areas/pieces of the old bottom paint have come off easily, especially with the help of a putty knife.Paint manufacturer (Interlux) suggested I rough up the areas with 80 grit and sand, then wipe with 216 thinner and paint. I went so far as to sand , but then noticed white dots appeared below the surface.
Any ideas as to what might be happening,how to approach this?
There is a formula that you must run. It is a weighted formula you are the only person who can assign those weights. I am of the opinion that Catalina 25s can have a less than perfect bottom and it is just fine. I spent thousands on my 82 and never should have. Considerations: Are you wealthy? Are you anal? Are you handy? Is there someone who will do it for you? Is there a place you could do it yourself? Are they smaller than a quarter? Are you changing types of bottom paint? How much time do you spend one the hard? Do you have a trailer? Has the boat been out of the water for a long time? Are people pointing and staring? You need to decide whether you can sleep at night with small blisters on your hull.
