 Installing AC - thru hull and liner
Initially Posted - 06/20/2006 :  20:08:26  Show Profile  Visit britinusa's Homepage
Next challange in installing the AC is the discharge thruhull.
It's supposed to be above the water line but below the discharge pipe on the AC unit.
That will put it about on the same level as the bathroom sink discharge. The pipe is supposed to be a single incline from the hull to the discharge pipe on the AC. ie. no high point in between the two ends.
I want to position the thru-hull just aft of the hanging closet transverse bulkhead.
However, that requires the thru-hull goes through both the Hull and the Liner!
Has anyone done this (run a thru-hull thru both the hull and the liner)
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Tom Potter
Response Posted - 06/20/2006 :  20:13:01  Show Profile
Not having done that, I would expect you would have to cut a larger hole in the liner, large enough so that the through hull nut fits through the liner so to get a good fit against the hull.
Edited by - Tom Potter on 06/20/2006 20:14:05
Response Posted - 06/20/2006 :  20:55:06  Show Profile  Visit britinusa's Homepage
Pilot hole through both, then large hole saw from inside through liner, then small holesaw from outside thru hull. Sounds like a plan.
(not doing it right now, watching the heat game )
