 Keel Pin
ed_spengeman
Initially Posted - 06/26/2006 :  08:54:27  Show Profile
Given: 1983 SK/TR; new cable; new ball, planned trip to Lake Michigan for crossing(+ or - 90 miles).
Did 80 miles up the coast last year and can't wait to get back.
Have the parts from Catalina Direct to do the hinge, pin and eye but my daler is booked and the money is a little rich now since I have to replace the sails I blew out last week-end (another long story)
Dealer told me the pin is quite husky and that it is usually the cable that breaks. Since I will have the keel down, that doesn't seem to be a big issue. He said what usually happens is that you hour-glass the hole in the keel that gives the slop I have.
My intent is to put the shims from Catalina Direct in and go for it. Put the kit in when timing is better.
Any suggestions? I don't wnat to take a chance on losing the keel 50 miles from shore in less than tropical water..
ed spengeman
Indianapolis (geist)
Port Captain
Palakida
83 tr/sk
Response Posted - 06/26/2006 :  09:16:09  Show Profile  Visit Leon Sisson's Homepage
Is the boat now, or will it be, hauled out before your big trip? If you're concerned about the reliability of the swing keel pivot assembly, I'd suggest inspecting the pin and replacing the four bolts. You might be able to get some idea of the condition of the pin without removing it. I agree with your dealer:<ul><li>The pin is 1" bronze. I've only seen photos of one pin which was hourglassed to a scary degree.</li>
<li>The pivot hole in the cast iron keel tends to 'hourglass'. Some folks compensate with shims, others install a bronze pivot bushing. (Mine has a bushing.)</li>
<li>The four little stainless steel bolts supporting the pivot should probably be replaced at least every few years, or when a haulout makes it convenient to do so.</li>
<li>While the keel is down, the condition of the cable is not an issue.</li>
</ul>
ed_spengeman
Response Posted - 06/26/2006 :  14:35:14  Show Profile
Leon:
Thanks for the fast response. It would be a good idea to at least replace the screw EXCEPT I have this morbid fear that one of them will break off in the process putting me in a real fix.
My trailer is not one of thge easy ones to use in dropping the board. Maybe I'll try it.
Have you heard much about the screws breaking off?
Ed
steephen
Response Posted - 07/16/2006 :  21:49:41  Show Profile
Swing Keel hanger and pin replacement.
1) Have the boat on jack stands and the keel winched all the way up (horizontal and parallel to the ground). The bottom of the keel could be two feet or so off the ground.
2) Crack the four bolts loose. Crib up below the keel with enough timber to allow a hydraulic house jack to sit between the cribbing and the keel. The jack I used was less than a foot tall, and the “meat tenderizer” points grabbed the keel very well. Have on hand wooden shingles to use as shims to fine tune the cribbing.
3) Alternate wedging the cribbing and loosening the bolts until a stout block adjacent to the jack will support the weight of the keel. No threaded rods are required, and the bulk of the keel is still in the slot, so the keel can’t keel over. It is only down about six or eight inches when the whole pin and hanger fitting assembly becomes exposed. One can crib the cable end of the keel to feel more secure.
4) I bored out the wobbly 1” hole with an inch and a quarter bit (1.25”), and a jig of my own making, as follows. Screw (no glue) four rectangles of ¾” plywood together; the four pieces are maybe four inches by fifteen. Notice that the area around the keel pin hole is pretty flat, and perpendicular to the pin bore. The bit I used was six inches long, purchased at an industrial machine tool shop. When making the jig, keep the wood screws away from the center. Bore a hole through the center of the jig on a drill press. You should now be in possession of a dis-assemblable (?) jig about four by fifteen, and three inches thick, with a 1.25” hole through the center.
5) Align the jig with the keel pin hole, and secure it with two large “C” clamps. Use a one inch dowel to get the jig hole aligned as much as possible to the keel hole. Then start drilling, using plenty of cutting oil. The jig will keep the bit aligned with, and parallel to, the old pin hole. Truth is, you’re not removing that much metal. When the drill chuck reaches the plywood, unscrew one thickness (3/4”) of plywood, re-align and re-clamp, and continue. I went through the keel in about ten minutes.
6) Get the keel pin, spacer sleeve and hanging brackets from Catalina Direct; new bolts come with it and the whole kit is around a hundred bucks. The outside diameter of the sleeve will be the same as the new bore; the pin is one inch diameter (as is the original), and the sleeve wall thickness is an eighth inch. You will have to carefully measure the keel thickness at the pin hole, and have the hanging brackets cut down to size, as they come larger (thicker) than needed. The machine shop at my local community college took this project on as a student task, for the price of two large pizzas.
7) Hammer the new sleeve into the newly bored hole, using something like BoatLife as both lubricant and adhesive. Reassembly is the reverse of taking down the keel. Jack it up slowly, fit the bolts, and tighten and jack alternately. I’m still trying to find out the correct torque, or if that is important. The kit comes with blue locking sauce for the bolts.
8) Since the keel is horizontal when you start, it does not advance towards the bow as you unbolt it; thus no need for threaded rods. My brother and I did this whole thing in one day, not including having the blocks milled at the tech school.
Response Posted - 07/16/2006 :  22:24:44  Show Profile  Visit Frank Hopper's Homepage
ooo someone is about to get a promotion.
