As a result of my t-boning incident, I've got a chunk missing out of the side of my boat. It's right under the genoa track, and it's about four inches long by two inches deep. The hull is undamaged, so my reading is that the damage is mainly cosmetic. The recommendation I have received is to fill the hole with "Bondo". It's some kind of polyester fill with long fiberglass threads. Evidently, you can shape it and then paint it. I thought that instead of paint, I might buy some of the custom gelcoat from Catalina Direct and use that for color match.
Comments?
Bruce Baker Falls Church, VA "Yee Ha" 3573 '83SR/SK
I've done some structural fiberglass work, and some minor cosmetic fiberglass repair. In my mind, Bondo is associated with quick and dirty cosmetic patches which subsequently fail. That might just be me. If you're dealing with a hole punched through fiberglass, I'd suggest repairing it with fiberglass. If you're only looking at scraped off gellcoat, then fix it with gelcoat. Putty like fillers fit in between those two extremes. For such thin shaping and fairing situations, I mix up filler putty from WEST epoxy and additives. They have stuff to discourage running, aid sanding, add strength, color tints, etc. I think with a little study and practice, you could whip up small custom batches of filler which would better suit your needs than Bondo. There's some disagreement about how well gelcoat goes on over epoxy. I've done it several times with good results. The WEST epoxy folks have some excellent technical papers on that, and other boat-specific uses of their products. Have fun smearing and sanding!
(edited to fix a stunningly obvious spelling error, as opposed to the slightly less obvious kind which are undoubtedly still in there.)
On my other boat some PO had used Bondo or some type of filler for a poor repair job (I'm not positive it was Bondo). When I made my first attempt at a repair with polyester resin and glass mat I found the Bondo was incapatable and I had to redo it all. I had to sand every bit of the old Bondo away before the fiberglass repair would hold.
Bondo is okay if you don't have a conscience and are planning on selling the boat after you fix the damage. You have fiberglass damage, so use fiberglass products to repair. You'll be happier with the results and if you sell, you will be able to say to the new PO, that you did the repair properly.
The only time I'd use Bondo would be as a quick fix in a non structural situation to get me through the sailing season, and then I'd remove it and do it right.
