 Inflatable speed
Initially Posted - 07/28/2006 :  22:53:13  Show Profile
In an effort to find enough fun on the water for everyone so I can sail more, I'm toying with getting a small Zodiac to tow my boys on tubes or wake boards.
Obviously, the larger models with a 40-50 hp kicker would work. But I'm wondering if any of you have recreated with an air hull and smallish outboard.
lcharlot
Antigua and Barbuda
Response Posted - 07/29/2006 :  01:00:02  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Paul</i>
<br />..I'm toying with getting a small Zodiac to tow my boys on tubes or wake boards.
If you are talking about a regular soft-bottom Zodiac, forget it. You could tow a wakeboard or water toy behind a RHIB (rigid hull inflatable boat), but probably not a soft-bottom. There are two reasons for this:
1. The fabric bottom of a soft-bottom dinghy is under tremendous stress at planing speeds, and this causes it to not have an ideal shape, which puts a lot of drag on the boat. Anyone who has owned both a soft bottom dinghy and a RHIB will tell you that RHIB's plane much easier than softies, and will plane with a smaller motor, and heavier load, than will a softie.
2. The transom board of a softie is basically just glued to the tubes. To pull someone on skis or a water toy would require so much engine power that you would probably be overstressing the transom-to-tube joint, leading to premature failure. The transom on a RHIB is an integral part of the fiberglass or aluminum hull, and is therefore much stronger.
I suspect that no inflateable boat designed and marketed as a dinghy is warranted by it's manufacturer for towing waterskiers or water toys.
atgep
Response Posted - 07/29/2006 :  10:07:59  Show Profile
I would guess that 35 HP would be the minimum to plane 12-13 foot rib and pull a tuber.
Tom.
Response Posted - 07/30/2006 :  18:56:07  Show Profile
If you want your boys to have some fun with an inflatable, get a DUX. A few years back, a former coworker of mine bought one of these and he said it was a blast. I saw two of these once while out on the water and I couldn't believe how fast they were.
