 Roller furling
panhead1948
Initially Posted - 08/15/2006 :  13:32:29  Show Profile
I have a 84 model with Hood roller furling. At the present time the furling line is lead aft thru fairleads on the stanchions to a cleat on the stern rail. I am not real happy with this setup. I thought of putting a cleat on the side of the coaming but would like to hear how others have handled this problem.
mfasis
Response Posted - 08/15/2006 :  14:16:06  Show Profile
I also have a Hood furler. I have the cleat on the port side coaming. Just forward of the shore power inlet.
Response Posted - 08/15/2006 :  14:53:31  Show Profile
I chose the simple route with a stanchion mounted cleat that takes all of a minute to install. It also provides an out of the way place to stow the line.
Edited by - dlucier on 08/15/2006 22:11:46
Response Posted - 08/15/2006 :  16:03:51  Show Profile  Visit Frank Hopper's Homepage
I run my line along the stanchions through Harken Micro blocks, (Just because I already had them) and to a "Lance Cleat" on the coaming. I haul through a Ronstan Magic Ratchet with an 8:1 holding power. It is load sensitive so it freewheels when the load is light and really helps when the load is heavy. I also have a jam horn cleat on the sternrail for high wind cleating and for when I put her to bed.
Response Posted - 08/15/2006 :  17:41:48  Show Profile
I added an enclosed cam-cleat on top of the coaming.
Response Posted - 08/15/2006 :  21:19:17  Show Profile  Visit aeckhart's Homepage
Cam cleat on starboard coaming. Cam cleat for asymetric spinnaker tack line on port coaming.
ilnadi
Response Posted - 08/16/2006 :  00:13:47  Show Profile
<br />I chose the simple route with a stanchion mounted cleat that takes all of a minute to install. It also provides an out of the way place to stow the line.
&lt;&lt;picts&gt;&gt;
We have the same setup, except at the bottom of the stantion where the cleat is mounted we have a block with cam (http://www.harkenstore.com/uniface.urd/scpdinw1.ShowProd?B4RPMEB9Y9A7N4). It holds the sail in until we cleat it. Very useful when trying to roll up in high winds because there is no slipping back out in between hauls.
