 Batteries and charging
AADIVER
Initially Posted - 08/21/2006 :  21:10:00  Show Profile  Visit AADIVER's Homepage
I want to replace my wet cell Group 24 12 volt battery for a Group 8G24 maintenence free gel battery. Will my Guest Battery Pal MAGNUM 3 amp, 12 volt charger work with a gel? Thanks.
Frank Farmer
Long Beach, CA
aa.diver@verizon.net
http://mysite.verizon.net/aa.diver
PRETTY PENNY
'01 C-250 WK, Hull #558
AADIVER
Response Posted - 08/21/2006 :  22:50:33  Show Profile  Visit AADIVER's Homepage
Answer to my question:
3 Amp Portable Charger
Part No. 2603
Description
Total Amps: 3 Amps
Number of Outputs: 1
Batttery System: 1-12V
Output Voltage: 12VDC
DC Output: 4' Output wires w/alligator clips
Input Voltage: 100-130VAC /50-60Hz
Input Connection: 6'AC cord w/standard plug
Dimensions: 3.1" x 3.5" x 2.34"
Weight: 1 Lb.
Product Features
Reverse Polarity Protected
Short Circuit Protected
3-Stage Switching Electronic Circuit
Maintenance Mode protects batteries during storage
Fully Potted to Waterproof Electronics
Vibration and Shock Protected
Self-Protecting under extreme ambient conditions
For Flooded, Gel and AGM batteries
2 - Year Limited Warranty
Meets all Guest Harsh Environment Guidelines
JimB517
Response Posted - 08/22/2006 :  13:44:16  Show Profile  Visit JimB517's Homepage
Gel batteries are good because they can't spill acid when the boat is heeled over. Gel batteries have slightly less amp hours. Gel batteries are very sensitive to overcharging. I have gels. I turn on up my battery charger once ever few weeks. Even though it has a float charging stage, I don't leave it charging for long periods of time. Works fine. Don't cook your batteries.
Response Posted - 08/22/2006 :  13:54:11  Show Profile  Visit Frank Hopper's Homepage
At three amps he may need to cook'm for a while!
AADIVER
Response Posted - 08/22/2006 :  20:19:19  Show Profile  Visit AADIVER's Homepage
Installed the new gel cell this morning. The charger LED was steady red. This afternoon it was steady green. With my wet cell it pulsed green, indicating fully charged and standing by. May I assume this will also pulse eventually?
Response Posted - 08/23/2006 :  11:00:23  Show Profile
Frank,
Are you sure the blinking is not indicating charging and the steady green incicating fully charged? You may have missed the blinking?
AADIVER
Response Posted - 08/24/2006 :  11:08:41  Show Profile  Visit AADIVER's Homepage
Per the Guest manual:
"When the green LED turns on, your battery is already at or near full charge, and the charger is now maintaining the battery. <u>If the green LED gradually fades on and off, this is an indication of an unusually efficient battery".</u>
So I guess my 50 buck wet cell was more efficient than my 180 gel cell
