 CDI Furler-Tough Furling
Cate
Initially Posted - 09/11/2006 :  13:13:46  Show Profile
On our last outing this weekend we had some rough conditions and I had to furl our 140% genoa. I was able to bring it in, but the last few turns were very hard. I was pulling with all my strength. Sheets were loose, headed into the wind. Our CDI furler has ball bearings so I can't figure out why it was so tough bringing in the last few turns. Any ideas? (This has happened more than once)
1983 C-25, Standard rig, swing keel
Response Posted - 09/11/2006 :  13:32:59  Show Profile  Visit Frank Hopper's Homepage
Good question, I have had my CDI with new bearings act up a little on me as well. The problem is probably line over=ride related, We tend to let the sails out without a lot of thought as to how the line is reeling up, I think that the line does not roll up well sometimes. About all any of us can do about that is make sure our lines lead as fairly as possible to the center of the spool and try to control the unfurl event a little to keep a little drag on the line. Also the last few turns have a much smaller diameter to the wheel of the wheel and axle simple machine that you are using so the gearing gets harder.
That is my guess.
Edited by - Frank Hopper on 09/11/2006 13:34:42
Response Posted - 09/11/2006 :  14:04:04  Show Profile
When you pull out the sail, make sure to keep some tension on the furling line so it winds fairly tightly on the drum. Gloves help--preventing a rope burn. If the line is wound too loosely, when you pull on it, the outer turns can jam down into the inner turns. The harder you pull, the worse it jams. Frank's "leverage" theory might also have something to do with it...
You might also try furling with the genny filled rather than luffing. For me, that actually seemed to make furling easier, as long as the sheet was being played out and the sail was being kept just barely filled. You can continue sailing on the main, and then luff up to drop that later. (I often daysailed on just the genny for simplicity--like raising and lowering a window shade.)
Cate
Response Posted - 09/11/2006 :  15:15:04  Show Profile
<br />When you pull out the sail, make sure to keep some tension on the furling line so it winds fairly tightly on the drum. Gloves help--preventing a rope burn. If the line is wound too loosely, when you pull on it, the outer turns can jam down into the inner turns. The harder you pull, the worse it jams. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I use gloves always, but I haven't paid close attention to keeping slight tension on the furling line when pulling out the sail. Good advice.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">You might also try furling with the genny filled rather than luffing. For me, that actually seemed to make furling easier, as long as the sheet was being played out and the sail was being kept just barely filled. You can continue sailing on the main, and then luff up to drop that later. (I often daysailed on just the genny for simplicity--like raising and lowering a window shade.)
I have been practicing a lot with just the genoa to get my timing right on the tack. Some embarassing stories there. I may try furling with a slightly full sail in a light wind on a port tack since my furling line is located there and I can control both the genny sheet and the furling line.
I think our next time out I'll keep a good eye on how the furler line is fairing on the drum. That seems to be the place where my problem is occuring.
pelican
Response Posted - 09/11/2006 :  18:10:41  Show Profile
Cate, just a bit of experiecnce here.
Lived and sailed aboard a 34 O'Day for 4 years with Hood furling system. Same idea should apply to a Cat 25(wish mine had roller furling!). To furl, always keep a bit of tension on the furling line and also on the sheet when furling. This gives you a nice snug sail rolled up and no problems with overlap on the furling line. Also keep a little tension on the furling line when pulling the sail out. Don't let it just whiz out.
Don't ask how I know this, just try it!
Also my RF had DELRIN(Plastic) bearings in the drum. Easy fix for sticky rolling was to use a hose and spray water down in the drum as you work it back and forth. There was always spider webs built up in there, and washing them out made it feel like new again.
Hope this helps you.
Robert
Response Posted - 09/12/2006 :  13:18:07  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Cate</i>
<br /> <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">You might also try furling with the genny filled rather than luffing. For me, that actually seemed to make furling easier, as long as the sheet was being played out and the sail was being kept just barely filled.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I may try furling with a slightly full sail in a light wind on a port tack since my furling line is located there and I can control both the genny sheet and the furling line.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I often did it on the tack where I was sheeting on the opposite side from the furling line--I think you'll find it's no more difficult.
bmelchionda
Response Posted - 09/12/2006 :  13:23:36  Show Profile
I experienced the same issue on my Furlex unit. A little bit on grease lubricant resolved all my problems. Besides the groups recommendations above, if you are still having issues, try some grease per the manufacturers instructions.
osmepneo
Response Posted - 09/13/2006 :  15:38:57  Show Profile
I have a cdi without bearings and one day that went from flat to 25 almost instantanously. The furler jammed as I tried to bring it in and I couldn't free it. I don't know the cause but as suggested suspect it has to do with winding the furling line too loosely. Since I've tried to keep tension on the line, to get a better wrap and have not havd a problem.
ilnadi
Response Posted - 09/13/2006 :  15:52:32  Show Profile
The furler jammed twice last Sunday. I thought I'd have to grease the bearings (which I may anyway) but I never thouht of the furling line zipping into the drum. In hindsight, it could not be the bearings becaue I went forward and could easily turn the furler by hand. No resistance. You may want to do that check next time.
Response Posted - 09/13/2006 :  22:34:07  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ilnadi</i>
<br />The furler jammed twice last Sunday. I thought I'd have to grease the bearings...
Some brands (particularly with Delrin ball bearings) specify <i>no lubricants</i>--just periodic wash-downs with fresh water. Check before you grease.
ilnadi
Response Posted - 09/13/2006 :  23:08:18  Show Profile
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ilnadi</i>
Good point, RTFM!
Cate
Response Posted - 09/18/2006 :  12:37:52  Show Profile
Here is an update on the tough furling situation...my lead into the furling drum is high and therefore the drum spools from the top and is forced down as the line spools. I unfurled and furled repeatedly from our dock and had many snags in the drum spool even while having various amounts of tension on the furling line. I wish I had pictures of my furler drum and furling line, but I didn't have the camera with me. My furling drum is very, very close to the deck.. about an inch. I notice the other sailboats in our marina have the furling drum much farther up from the deck. I may need an extension, but for now I'm going to put a fair lead on the forward most stantion and hope the line spools from the bottom up. Comments?
Response Posted - 09/18/2006 :  12:55:14  Show Profile
Cate,
If you have the fairlead attached to the stanchion you should adjust it so the furler line enters the middle of the spool. You will likely encounter additonal problems if you spool from the bottom.
Cate
Response Posted - 09/18/2006 :  13:14:26  Show Profile
<br />Cate,
Ahh. Good advice Sloop. I was wondering about the optimum lead into the drum. I will make sure it spools from the center to reduce furler line snag. Thanks.
Dave Otey
Response Posted - 09/20/2006 :  05:07:09  Show Profile  Visit Dave Otey's Homepage
I too have had some furling problems and after experimenting found what others have pointed out. Without sufficient drag on the furling line the spool has a tendency to load up loosely creating what I call a bird's nest. Then when one tries to furl the genoa the tension on the furling line draws down between the loose wraps on the drum / spool. Once this happens the line almost locks down and the furling becomes difficult if not possible. BTW, the manufacturer recommends the line enters the drum at a 90 degree angle to the drum regardless of the height off the deck.
