 Four-stroke motor bracket
Initially Posted - 06/18/2002 :  16:13:23  Show Profile
The number of people upgrading to 4-stroke motors on this forum certainly seems to be increasing. A few of us assumed (incorrectly) that 4-stroke bracket made formerly by OMC went away when they were bought out by Bombardier of Ontario.
I spoke with Bombardier Johnson/Evinrude this afternoon and discovered the bracket is still being made. The part number for the 125 lb version is 175556. The list price is $494.40 but most dealers discount it. They also make an 80 lb version.
I used this bracket 4 years ago to mount my Yahama 9.9 4-stroke. In my opinion it is the perfect solution for mounting a heavy outboard on the transom of the C-25.
The Bombardier Johnson/Evinrude telephone number is (517) 355-6495 for more information. A customer service rep said they were currently on back-order because they are so popular.
Edited by - OJ on 06/19/2002 12:08:13
Response Posted - 06/18/2002 :  16:50:55  Show Profile
NOW you tell me! <img src=icon_smile_sad.gif border=0 align=middle><img src=icon_smile_wink.gif border=0 align=middle>
Daniel
Response Posted - 06/18/2002 :  22:16:48  Show Profile
I and some others have this (OMC) bracket and it is indeed very sturdy and easy to raise/lower. I have my 1997 Honda 15 XLS (118 lb) on it. Has a gas piston assist. Someone on this list did a good comparison of several of the brackets and this came out tops for the 4-strokes, so I got it. As I mounted it, the motor can tilt up entirely but needs to be rotated to clear the stern rail. I could probably adjust the bracket (there are two adjustment points) to make this a little easier, but haven't done it yet.
allencl
Response Posted - 06/18/2002 :  23:13:51  Show Profile  Visit allencl's Homepage
I also have the OMC bracket and think it's great. The previous owner mounted it with wooden wedges between the bracket and transom to set it off about 2 inches, so the Yamaha 9.9 is free and clear in all positions, including tilt.
You can lift and lower the engine with one hand, easily. I highly recommend it.
Cheers,
-Chris on "SPIRIT" C25 SR WK #5644
n/a
deleted
Response Posted - 06/19/2002 :  11:50:33  Show Profile
The OMC bracket with the wedges (Chris's set-up) is wonderfully easy to handle with the heavy four strokes. The wedges allow clearance at the stern rail. Now I can sail alone if I want to thanks to Chris's advice to add the wedges. Thank you, Chris!
