I have the fixed on my 88. I like it but have no experience with the sliding version on a C25. I suspect that the only real difference between the two is that I use a cunningham on my sail and you have a downhual on your gooseneck to tension the luff.
I imagine that the slider would allow you to reef the main and then reposition the boom and sail down or up the mast for optimal performance. Also I suppose it could be repositioned slightly to accommodate the stretching of a new sail as it ages. However I have found that the slider has a tendency to slide up over time if the crew gets too aggressive when raising the main sail. Duane I didn’t know that there is a fixed replacement. Do you have a photo or a reference web site where I can see one I might want to switch mine out also.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Renzo</i> <br />I imagine that the slider would allow you to reef the main and then reposition the boom and sail down or up the mast for optimal performance. Also I suppose it could be repositioned slightly to accommodate the stretching of a new sail as it ages...<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I had to reposition the gooseneck a little bit when I changed main sails.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by djn</i> <br />Hi Larry, here is a link to CDs fixed goose neck. I thought the saying was Cogito Ergo Sum. Cheers.
