 Cheap Laptop WeatherFax System
Initially Posted - 11/11/2006 :  17:29:59  Show Profile
Latts and Atts has a great article in the December issue on a weatherfax system that doesn't require single sideband to receive. All you need is a digital shortwave radio, a line to run from the radio to the laptops mic plug, and decoding software.
Basically, NOAA broadcasts on various frequencies at various times of the day. It soundslike a series of beeps and high pitched sounds. The software decodes the sounds into a picture. http://weather.noaa.gov/fax/marshlatest.shtml
I found a small Grundig at Brookstone for $30, a straight line plug at Radion Shack. Now all I need is the software. Ocens was recommended on the article, www.ocens.com, but they want a hundred bucks for it. Does anyone know of a freeware version?
Sten -'82 SR FK
Response Posted - 11/11/2006 :  19:44:23  Show Profile
Does the article say how far offshore the broadcasts can be received?
Response Posted - 11/11/2006 :  20:11:41  Show Profile
The author admits that the major drawback is the difficulty in grounding to a grounding plate, but indicates that you would get a lower quality signal while running the engine or using other stuff like an inverter. I have had shortwave radios for years and I've heard the tones when tuning in some pretty random places all over the world with a portable SW radio, I just never knew what they were. I believe that this system would benefit from an antenna. Radio Shack used to sell a retractable 30 foot antenna on a reel that I run up a halyard. This was offered as a cheap solution for cruisers instead of the $3,000 a SSB would cost.
sten
Response Posted - 11/11/2006 :  20:17:06  Show Profile
Important! I had to buy a new SW radio, because my old one did not have digital tuning. You have to be able to tune to exactly 1.9 KHz below the frequency on the schedule. I downloaded a demo from http://www.jvcomm.de/index_e.html to decode the data.
dontluff
Response Posted - 11/13/2006 :  19:47:28  Show Profile
yes you can certainly connect via the mic jack on the PC.
Even better is to get a satphone for under $1,200 and a related email account from a service provider like GlobalMarineNet and you will get telephone calling (great for emergencies), free text messaging, email, weatherfax downloads, Internet website browsing (a bit expensive-but available) and grib files for wind, waves, pressure, etc...that can be requetsed via email, and uploaded into your PC nav package.
I bought one for this year's Vic Maui and although we had a SSB on board, trying to get through when you needed another grib file was a hassle (given the majority of other boats trying to connect via SSB) and very slow.
I bought special deals on the call cost and prepaid 500 minutes for $1.35 a minute. For racing offshore, this is worth the cost. For cruising, I would suffer with the SSB but still have the satphone for emergencie with a smaller amount of prepaid minutes.
