 Bilge pump question...
alligood
Initially Posted - 11/27/2006 :  17:41:05  Show Profile
I want to replace my manual bilge pump with a brand new one. It's mounted inside the sail locker with the handle being inserted through a cutout (with a nice plastic lid ensemble) around ankle high in the cockpit. You pump up and down while sitting on the port side bench. I think this is referred to as a bulkhead mount?
I also plan on installing new electric pumps, but want a rock solid heavy duty manual one as well. Any brands or other advice would be greatly appreciated!
Thanks.
dblitz
Response Posted - 11/28/2006 :  19:06:34  Show Profile
The hose connected to my bilge pump has just the slightest curve at the end, but enough to not be flush with the bottom of the bilge, so I use a hand pump that I stick in a bucket to remove the 3 quarts or so that accumulate there over about 2 weeks time.
Had considered installing an auto electric pump, but the boat didn't have one when I bought it. A very helpful salesperson at a marina wanted to know why I was going to install an auto, electric pump in a 20 year old boat that never had one before.
Response Posted - 11/28/2006 :  20:11:27  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by alligood</i>
<br />I want to replace my manual bilge pump with a brand new one.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Is there something wrong with your current manual bilge pump? If so, you might be able to get it going again with a maintenance kit.
If its a Whale pump, they may have a rebuild kit for it.
[url="http://www.whalepumps.com/marine/product_list/7/"]Whale Manual Bilge Pumps[/url]
Defender carries the service kits and prices are very reasonable.
[url="http://www.defender.com/category.jsp?path=-1|51|299222|84462|316440&id=315120"]Whale Henderson Pump Accessories[/url]
Edited by - dlucier on 11/28/2006 20:18:49
Response Posted - 11/29/2006 :  10:11:09  Show Profile
West generally has the kits, too. The usual failure is in the rubber bellows--often from water freezing in it. So, winterizing should include pouring some pink stuff in the bilge and pumping it out so some remains in the pump. I leave some in the bilge in case water finds its way down there.
DaveC25
Response Posted - 11/29/2006 :  15:51:17  Show Profile
Speaking of manual bilge pumps, where is the factory one located. I have never seen mine.
It may not be with the boat anymore.
-DaveC25
dblitz
Response Posted - 11/29/2006 :  17:00:53  Show Profile
There is a cutout with a rubber cover for you to put in the handle on the port side of the cockpit.
You can see the pump if you lift up the cover of the locker.
