 Is #900 born yet?
Initially Posted - 12/04/2006 :  22:08:09  Show Profile  Visit britinusa's Homepage
the C250 owners page has #898 listed.
anyone know if #900 has already broken water?
At this rate, #1,000 should be due around August 07 (nine months from now
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Chris Z
Response Posted - 12/05/2006 :  10:19:35  Show Profile  Visit Chris Z's Homepage
This might be it right here.
http://www.sailboatsindiana.com/2007_catalina_250_wb.htm
sterngucker
Response Posted - 12/05/2006 :  13:47:09  Show Profile
That boat is #917 according to Craig at Sailboats Inc. in Indiana. I noticed it comes with a 135% furling jib. Hmmmm... I could sure use a little more sail area than my 100% offers.
Response Posted - 12/05/2006 :  14:13:04  Show Profile
That last photo looks like a wing keel under there.
welshoff
Response Posted - 12/05/2006 :  16:40:49  Show Profile
Is it just the picture or is the shelf missing over the galley?
Response Posted - 12/05/2006 :  17:52:31  Show Profile  Visit britinusa's Homepage
Wil, the 2006 model and later does not have a shelf at the galley (at least JD never had one till I put one in)
Do you have one on yours? (curious to see it.)
paul.
Chris Z
Response Posted - 12/05/2006 :  18:08:12  Show Profile  Visit Chris Z's Homepage
He notes that wing keel is available, however this one is a WB.
Tom Potter
Response Posted - 12/05/2006 :  19:30:43  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by welshoff</i>
<br />Is it just the picture or is the shelf missing over the galley?
The shelf is a WK thing, WB's don't have the shelf.
mhartong
Response Posted - 12/05/2006 :  20:19:32  Show Profile  Visit mhartong's Homepage
We're well over 900.
Persephone was delivered 15 Nov 2006
Mark
Response Posted - 12/06/2006 :  06:52:30  Show Profile  Visit britinusa's Homepage
Mark, Congrats, keep her kindly!
From the pics on your site I see several differences in the galley area of the WK-v-WB. As pointed out that shelf is not there (lower headroom probably enforced that decision). And the tube from below the electrical panel is not present in the WB (I had to make my own routing for electrics that provide power for the AM/FM/CD unit I installed on the fwd side of the galley unit and for the water pump installed under the galley floor.
Nice Name!!!!
Looks like #1,000 should splash around June 07 at this rate.
Paul.
welshoff
Response Posted - 12/06/2006 :  10:37:05  Show Profile
Mark,
Nice looking boat - you should have fun with your new boat.
Here are a couple more changes I noticed on Mark's boat from my boat:
1) They added a starboard mounting plate under the table pedistal receiver on the floor. That looks good - in my boat the pedistal receiver is mounted right to the floor.
2) They added two clam shell vents on the stern. Do these vent into the rear berth or the rear battary/storage area? I like the look of these on the boat.
Paul,
I don't have any photos of the shelf. It looks just like the one in the photo of Mark's boat. I wish it had the teak trim like Tom put on his shelf (see his web site).
Note: I thought the ss tubing below the electrical panel was the routing for the gas to the stove?
Response Posted - 12/06/2006 :  11:05:48  Show Profile
At this rate, in about 60 more years you'll match the C-25 run!
Tom Potter
Response Posted - 12/06/2006 :  12:33:52  Show Profile
Wil, Your right, the propane line from the cockpit locker to the stove runs through that SS tubing.
Russ.Johnson
Commodore
Response Posted - 12/06/2006 :  17:22:22  Show Profile
<br />Mark,
I think the 2 clam shell vents are for the inboard diesel.
The stainless steel tubing was used for the cockpit Propane tank.
Mark's boat has the new Butane stove without the cockpit tank.
I'm wondering if it's used anymore?
Also, there is a tall wheel guard in front of the compass.
Was that extra?
My 2005 model, it didn't come with the guard (it's on my Christmas list).
Mark, I like your setup.
Russ #793
Response Posted - 12/06/2006 :  18:32:44  Show Profile
Mark,
The detailed analysis that you did prior to purchasing Persephone is quite impressive and a very nice read! Thanks.
mhartong
Response Posted - 12/06/2006 :  20:48:40  Show Profile  Visit mhartong's Homepage
The DFO tank replaces the battery in the stern, and the batery is located foward, under the Vberth on the centerline.
The wheel guard was installed by Catalina.It is an "unpublished factory option". I actually saved money having Catalina doing the job. Plus THEY were drilling the holes.
