 protocol
mashedcat
Initially Posted - 12/08/2006 :  22:10:49  Show Profile
how do you get the lines to appear around, make smaller print, and get the quote of the pertinent part of the thread that you want to respond to as i see so often in the forum??
dave
Edited by - mashedcat on 12/11/2006 22:24:12
Brooke Willson
Response Posted - 12/08/2006 :  22:18:07  Show Profile
The protocol is . . .
1. highlight the text you want to quote, and copy.
2. click on "Reply to Topic," instead of using Quick Reply.
3. click on the next to the last button on the right, which should show "Insert Quote."
4. put your cursor between (quote) and (/quote). . . (I can't use the brackets because then it acts like a quote in this reply).
5. paste
6. cursor down to the next line and make your comment.
Brooke
Edited by - Brooke Willson on 12/08/2006 22:19:52
Russ.Johnson
Commodore
Response Posted - 12/08/2006 :  22:25:38  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Brooke Willson</i>
<br />The protocol is . . .
5. paste
Brooke
You can also click the "Reply with Quote" icon
Response Posted - 12/08/2006 :  22:31:38  Show Profile
As Russ stated, click on the "Reply with Quote" icon that is above the text you want to quote. Go ahead and give it a try.
mashedcat
Response Posted - 12/08/2006 :  22:33:14  Show Profile
Thank you. I apologize for my clumsiness
mashedcat
Response Posted - 12/08/2006 :  22:41:57  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mashedcat</i>
<br />Thank you. I apologize for my clumsiness
Response Posted - 12/09/2006 :  06:25:13  Show Profile  Visit britinusa's Homepage
That's the icon that is present in each post.
Response Posted - 12/09/2006 :  09:20:51  Show Profile  Visit Champipple's Homepage
You can also used the reply at the very top of the thread.
That will allow you to
add a line -
<hr noshade size="1">
Insert a URL
www.google.com
add a numbered list, insert a quote etc, use bullets and smilies. change font size alignment etc. It also has pop up dialog boxes to help you out with this. When you reply to a thread using the button at the very top or very bottom (not the one above each post) you will be able to change the format mode from basic to Prompt.... Go to the Testing area and play around.
Duane
mashedcat
Response Posted - 12/09/2006 :  12:10:36  Show Profile
