Can anyone recommend a good replacement window for the location above the head? Having it open is optional. I'm just looking for a Make/model that will go in with minimum effort.
I'm replacing mine with these.. (and someday I'll actually get the boat done). These are Bomar opening ports. I purchased them from Defender industries.
[url="http://home.wmis.net/%7Edhapp/portlights/newlights.jpg"]Bomar 1[/url] [url="http://home.wmis.net/%7Edhapp/portlights/bomar6.jpg"]Bomar 2[/url] [url="http://www.defender.com/category.jsp?path=-1|6880|296549&id=320597"]The Link to Defender[/url] Mine is hull number 29 so it's one of the first ones built. Yours may have a different opening. I would suggest measuring the opening first. You should be able to remove the interior trim piece and measure the cutout without disturbing the sealant on the outside. The 2414/N2414 would have fit without cutting the opening but the fit would have been a little sloppy. I bought the 2515/N2515 and had to trim the opening to fit the port light, but the fit is nice and tight. I wanted maximum flange overlap to provide maximum seal against leakage. The 2414 would have only had about 1/4" flange overlap in some spots so I went with the larger port. Trimming the opening larger was pretty easy. I used a 2" drum sander in an electric drill. If you put a blower in the companionway, all the dust goes outside. I forget what the N designator is, but I think it is white powder coat as opposed to aluminum finish. I bought two, one for each side. I have a ton more pictures if your interested. Dan
