 Bilge full of rust ...Keelbolt replacement?
rs-nhs
Initially Posted - 01/03/2007 :  18:53:27  Show Profile
I recently bought a wonderful C25 with a fixed fin keel. She had 5 or 6 gallons of water to pump from the bilge and various compartments at the start of cleaning out the cabin. She has been sitting on the hard for a few years having received no attention. I discovered that the bilge was full of both water and rust. The keel bolts are badly corroded and I cannot even find a nut on some of the bolts! The keel to hull joint on the exterior of the hull looks great but I think it's got to be time for a reistallation of keel bolts.
Does anyone know how well the kits from Catalina Direct work and/or how much of a job the replacement of 6 bolts actually is? Are there less costly alternatives to Catalina Direct's keelbolt kits?
I have not yet determined if she has a cast iron or lead keel but will do so when the yard reopens in a few weeks. It would seem that a lead keel would be a bit easer to work with since the lag bolt holes do not need to be tapped. The extra expense and the prospects of drilling and tapping 24 inches inches of cast iron is daunting. I wonder if my cordless heavy-duty drill is up to the job without making multiple trips to the yard.
Many thanks in advance to those of you who can share your experience and wisdom!
Response Posted - 01/03/2007 :  21:47:36  Show Profile
Popular issue. Check out this link.
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=14167
Response Posted - 01/03/2007 :  23:33:01  Show Profile
Welcome, Bob, and congratulations! There are several threads on this topic in addition to what John pointed to... You can use the Search function, looking for "keel bolts", to find them (and lots of other stuff you'll be learning about).
The short answer is if you have rusty bolts, you have a pre-84 fin, which has a cast iron keel. Adding bolts (they can't be "replaced") is discussed and debated on several threads--you can get the whole story there.
Response Posted - 01/04/2007 :  12:15:37  Show Profile
You might want to check this posting:
http://sailing.cnchost.com/board/?topic=topic3& msg=248
It sounds a lot like what Jim Baumgart talks about. One thing of note is they mention you should not place stainless studs in a cast iron keel. This would seem to agree with what others have said on this forum regarding the use of stainless hardware. The writer recommends galvanized bolts. The Catalina Direct kit provides stainless bolts.
Edited by - Sloop Smitten on 01/04/2007 12:16:36
oldsalt
Response Posted - 01/04/2007 :  22:37:06  Show Profile
I wonder if having a bilge full of water for so many years can cause other structural problems such as delamination of the laminate, freeze damage, rotten wooden members which are imbedded in the core to secure the keel and so forth?
Dave, lead keels with stainless steel keel bolts replaced cast iron/mild steel bolts in the '83 model fin keeled boats.
Edited by - oldsalt on 01/04/2007 22:45:10
Response Posted - 01/05/2007 :  07:53:10  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by oldsalt</i>
<br />I wonder if having a bilge full of water for so many years can cause other structural problems such as delamination of the laminate, freeze damage, rotten wooden members which are imbedded in the core to secure the keel and so forth?<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Could be... but many of these boats have a little "moisture" down there most of the time. Is there in fact a wood core in the stub? I never saw evidence of that, but I never took the keel off...
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Dave, lead keels with stainless steel keel bolts replaced cast iron/mild steel bolts in the '83 model fin keeled boats.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Sorry--I thought a friend's boat with a cast iron fin was an 83... Anyway, the difference is easy to spot--a non-metalic, glass covered surface outside and shiny bolts an nuts in the bilge.
oldsalt
Response Posted - 01/06/2007 :  09:06:40  Show Profile
Dave, I'm not certain that there is a piece of encapsulated structural wood in the keel stub but I believe there was a keel bolt replacement post on this forum that stated there was.
It stuck in my mind because I thought it was so strange when I read it.
Honestly, I don't think there is one on my boat but I could be wrong, and the wood, if present at all could be present on certain model years.
Does anyone know?
