 Table / hardware Request
moserd
Initially Posted - 03/18/2007 :  16:54:08  Show Profile
I have just built myself a 'smaller' version of the table for my 250 wing keel (2005). I plan on keeping the original table stored in the bow for when I need a bigger table. I suspect the extra weight may also play a valuable role. My new table uses a standard plumbing fixture (I believe it is from a toilet) as a receptacle / socket for the existing support post. This does not fit as well as the original fitting. I have noted that several folks have talked about getting rid of their existing table. Anyone out there want to sell the receptacle fitting from the bottom of their existing table? If so please let me know. I will try Catalina next but am not sure if they would sell this part as a single piece. On the wing keel the fitting in the deck 'appears' to be the same as that on the table.
Don
Don Moser
AADIVER
Response Posted - 03/18/2007 :  18:44:48  Show Profile  Visit AADIVER's Homepage
Don, check out my Easy Cabin Table Project on the 250 Tech Tips link. My table uses the existing, factory supplied pedestal.
moserd
Response Posted - 03/19/2007 :  07:06:45  Show Profile
Frank,
Thanks for the information; I could certainly use my existing Catalina 'socket' however I want to retain the use of my existing table so I don't want to remove my existing hardware. Hence my 'call' for those who no longer want / need their Catalina hardware.
So, anyone out there want to sell their un-used hardware? :)
Don
