 Rear trailer guides for boat alignment
Second Wind53
Initially Posted - 03/20/2007 :  14:31:28  Show Profile
Hi I'm new to the forum, bought a 1995 250WB last summer and have only launched the boat off the trailer once and had a problem with aligning the boat over the trailer when pulling boat back out.
Has anyone put struts up at the back of the trailer like the ski boat people have?
Thanks.
Peter
C250 WB #94
95 250WB #90
Vancouver, BC
Response Posted - 03/20/2007 :  18:52:00  Show Profile
I use them for my O'Day Daysailer. Really simplifies recovery. I'm not going to trailer my WK but that trailer has a guide for the keel that would probably preclude the need for the white PVC poles.
Response Posted - 03/20/2007 :  21:09:11  Show Profile  Visit britinusa's Homepage
On our last recover, we dropped the bow bunk, it made recovery a breeeeeze!
Our 'poles' are almost 10' tall so it makes it pretty easy to get the alignment right now. Dropping the bow bunk takes seconds and less than a minute to put it back up, it also totally removes the issue of the boat balancing on the bow bunk during pull out.
Paul.
Second Wind53
Response Posted - 03/21/2007 :  10:12:26  Show Profile
We collapsed one of the keel centering bunks when having the trailer in a bit deep to see if it was aligned. Was able to straighten it back on the ramp and recover the boat with trailer a little less deep in the water.
The boat goes on the trailer quite slick but it still is a 25 foot boat and I worry about doing damage on a bad recovery.
Does anybody have pictures or sketches for alignment poles?
Peter
zeil
Response Posted - 03/21/2007 :  10:48:11  Show Profile
Welcome to the forum Peter and congratulations with your new '95 C250 WB We're thrilled to learn of another C250 in the Vancouver, BC area. Our boat is also a '95 C250 #151 WB
It would be a real pleasure to meet and do some sharing and comparing... Only problem is we are presently in Florida with the boat and won't be home until sometime August '07.
We live in Langley, BC and have (had) a slip at Point Roberts Marina, WA and sailed Harrison Lake the Gulf Islands and the San Juan's. You gonna love that boat... besides... it makes a wonderful 5th wheel
(You may have an interest in our trip reports, "living on board full time and going South", one to nine, on this forum to get some impression of the capability of the boat)
Russ.Johnson
Commodore
Response Posted - 03/21/2007 :  12:19:36  Show Profile
Peter,
I have a Trail-Rite trailer, that has a step behind the 2nd axle.
The guide posts are mounted to the step.
The posts are 1-1/2 x 1-1/2 square galvanized steel.
They are 6' long, bent with a 14" base.
They are covered with 2" PVC pipe and 6' long.
The ends have caps which allow the pipe to float during launching.
Russ #793
Guide Posts with PVC
Guide Posts without PVC
The posts have to be above the rub rail.
Guide Post Base mounted to the trailer step
Edited by - Russ.Johnson on 03/21/2007 23:57:17
Response Posted - 03/22/2007 :  07:02:38  Show Profile  Visit britinusa's Homepage
Russ, we replaced our 6' poles with 10' poles. When the boat is afloat and the trailer in the water, the top of the pole is below the rub rail, we actually scratched the hull when the boat was lining up. The tall poles prevent that happening. The tall poles have a secondary value .. help support the tarp.
Do you jack your trailer all the time or were you doing repairs in that 2nd pic?
Edited by - britinusa on 03/22/2007 07:02:56
Russ.Johnson
Commodore
Response Posted - 03/22/2007 :  11:42:00  Show Profile
Paul,
We haven't had a problem with the 6' poles.
I'm pretty sure the trapped air makes them float during launch.
I know you don't want them to get caught under the rub rail.
But since the rub rail is about 3' above the waterline, they may not float high enough.
I'll check next time to see how high they float.
The boat is parked in the driveway and I don't think the neighbors would like a big blue tarp.
I always jack up the trailer when parked more than a month.
It saves the tires and wheel bearings. I also cover the tires.
Next, the driveway is slanted, so the port is jacked higher than starboard.
Rain would puddle in the port cockpit locker and in the anchor locker (starboard drain).
In the last picture, you can also see I chain the tires to the frame.
It doesn't get cold enough to put the tires in the garage for the winter.
Russ #793
Second Wind53
Response Posted - 03/23/2007 :  12:58:30  Show Profile
Thanks Russ good pictures. I notice that the upright portion of the post is not quite perpendicular. Is this to keep the bottom of the post out of harms way?
Looks like a real professional install.
I am sourcing out galvanized tubing around here.
Thanks again.
Peter
Russ.Johnson
Commodore
Response Posted - 03/23/2007 :  23:17:05  Show Profile
Peter,
Yes, the Catalina dealer installed the guide posts.
The rub rail is wider than the axle so it does flair out.
I never really looked that closely before.
Welcome to the forum.
There's quite a few folks that like to help.
Russ #793
