 Honda outboard
jking
Initially Posted - 03/22/2007 :  10:58:57  Show Profile
I have a Honda 9.9 XLS. the manual describes a clip or friction bolt to keep the motor from turning on it's shaft, but I don't have one. I have been using the small metal (not rust resistant) clip that keeps the motor from rotating during shipment, and would like something better. Does anyone have a similar outboard motor with a friction bolt?
John
250 WB #887
'Flying Wasp' , formerly 'MAD MOM'
Response Posted - 03/22/2007 :  11:11:16  Show Profile
If you have the newer version with the rounded cowl, the steering friction control is a flat bar on the front--just below the cowl and above the clamps. It slides right-to-left to control the friction. The older models have a bolt on the side of the shaft behind the mounting board. Is there a hole there with no bolt? I believe the bolt comes with a spring--a dealer should be able to get you a proper replacement.
Edited by - Dave Bristle on 03/22/2007 11:23:23
jking
Response Posted - 03/22/2007 :  11:20:38  Show Profile
Thanks. I do have the new model, but no control bar. Can you post a photo?
Response Posted - 03/22/2007 :  11:28:07  Show Profile
It's pictured on page 15 of a manual on Honda's site:
http://www.honda-marine.com/mar_pdf/31ZY0610.pdf
If yours is the remote steering model (for use with a wheel), it might not have that. Otherwise it should.
Edited by - Dave Bristle on 03/22/2007 11:28:54
Response Posted - 03/22/2007 :  11:33:28  Show Profile  Visit OLarryR's Homepage
I have a 2006 Honda 9.9. Dave's description of the flat bar in the front of the motor is same as what I have on my motor. It's just to the left of where the twist grip handle attaches to the motor.
Response Posted - 03/22/2007 :  11:44:56  Show Profile
Response Posted - 03/22/2007 :  12:37:13  Show Profile
(I was too lazy to do that.)
jking
Response Posted - 03/22/2007 :  12:55:16  Show Profile
I have the remote control model-no tiller. I wonder if that makes a difference?
Response Posted - 03/22/2007 :  13:07:29  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jking</i>
<br />I have the remote control model-no tiller. I wonder if that makes a difference?
I suspect so... You wouldn't want friction at the engine working against the steering linkage. It might be time to rig "Arlyn's Soft Link." (See the Tech Tips.)
