 Bilge pump retrofit on a '77
monty0
Initially Posted - 03/29/2007 :  11:49:36  Show Profile
So on our '77 there are no ports in the floor to access the bilge, and no pump installed. There is a hole right next to where the keel hose goes through the hull, which I just enlarged so I could stick a vacuum hose in there to suck out the water that's been there probably for years.
The manual we have suggests putting the pump pick-up in the keel stub under main cabin sole and using a 1" ID hose. How does the hose run from the pick-up to port cockpit locker? Does anyone have pictures of this kind of system? What kind of pump did you use? Where did you mount it?
Monty
1977 Catalina 25 #66 SRSK "Prana"
