 swing keel cable repair
mjnee
Initially Posted - 04/05/2007 :  19:49:23  Show Profile
This is my first season with a 250 wb. The cable for the swing keel is broken. Has anyone replaced this? What is the best way to access its attachment to the keel.
Inis Ni'
willy
Response Posted - 04/05/2007 :  20:10:05  Show Profile
The boat must be on a lift or high enough jackstands to lower the board and from there its pretty simple. Its been two years since I did mine but it is an intuitive process. When you see it its obvious. Takes all of 5 minutes once its up in the air!
bear
Response Posted - 04/06/2007 :  06:48:07  Show Profile
Plenty of help available for this, use search engine and select archives. Also make sure you get the replacement cable from Catalina
Parts
