 Stretching standing rigging
Ben
Initially Posted - 04/19/2007 :  05:41:13  Show Profile
Hi folks, I don't remember this from last year, which doesn't mean much because I have a hard time remembering what happened 15 minutes ago, but I had my first sail of the year (a race!) yesterday and the lowers are much looser than they were before the race. Is this normal? The boat was stored over the winter with the mast down, in case that sheds any light on the subject.
Ben
Beneteau 361
Viking Kitty
Columbus, Ohio
Bill Holcomb
Response Posted - 04/19/2007 :  08:14:06  Show Profile
Hi Ben,
Sounds like you didn't get the mast tuned completely when you raised it this spring. Here's a link to a mast tuning article that I wrote for the Mainsheet magazine several years ago. You can find it and other neat stuff in the tech tips section of the website.
http://www.catalina-capri-25s.org/tech/tech25/snkmast.asp
atgep
Response Posted - 04/19/2007 :  08:45:24  Show Profile
I have noticed a slight change in rig tune after the boat is in the water a few days. I attribute this to the hull flexing to it's "in water shape"
Tom.
Response Posted - 04/19/2007 :  08:59:42  Show Profile
"lowers are much looser than they were before the race."
Wouldn't worry too much... just for kicks, you might inspect the deck around the attachments and make sure nothing is pulling up. If you re-adjust they should stay pretty much in tune the second time around. Remember that you want the aft lowers want to be a bit looser than the front so you can adjust mast bend.
Response Posted - 04/23/2007 :  15:31:22  Show Profile
Are your turnbuckles pinned or wired so they can't turn? I tend to agree that when the boat has "settled" over the winter, the position of the lower chainplates might become a little lower, and the tension from your first sail of the season might pull them up a little.
Response Posted - 04/23/2007 :  16:40:16  Show Profile  Visit Champipple's Homepage
Most of the time they tell you not to permanently pin and tape anything until you've sailed her for a week. If it was blowing good enough it is possible that the rig loosened up a bit. I'd crank them back down and keep an eye on them. Make sure you ring them or pin them.
Edited by - Champipple on 04/23/2007 16:41:10
