 Head/sink thru hull
newell
Initially Posted - 05/21/2007 :  09:29:25  Show Profile
I can not find that this has been discussed as so will run the risk of asking again. Both the head intake and the forward sink drain into the same thru hull. As a result I can not pump water into the head unless the sink is full of water. What is the solution for this? Two shut off valves in the lines? Check valves in both lines??
Any help will be apreciated.
newell
Newell
1980 C25 SR/SK
AVALON
mfasis
Response Posted - 05/21/2007 :  09:53:27  Show Profile
Are you sure that the seacock is open? I have the same setup on my boat:
seacock with a "T"
Both head intake and sink drain connected to the "T"
If the seacock is not open then the head will draw water from the sink. Some people like this feature as it gives them the ability to flush out the head with fresh water.
newell
Response Posted - 05/21/2007 :  10:04:56  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mfasis</i>
<br />Are you sure that the seacock is open? I have the same setup on my boat:
seacock with a "T"
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yes............the seacock is open and the head will not pump from the sea without a prime poured into the sink.???????
newell
Response Posted - 05/21/2007 :  10:57:42  Show Profile
Have you tried a rubber stopper in the sink--to allow a vacuum to draw water up from the thru-hull?
newell
Response Posted - 05/21/2007 :  11:03:42  Show Profile
<br />Have you tried a rubber stopper in the sink--to allow a vacuum to draw water up from the thru-hull?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I will give that a try....thanks!
SJ
Response Posted - 05/21/2007 :  12:16:23  Show Profile
I installed a ball valve just above the seacock. No priming needed now...
newell
Response Posted - 05/21/2007 :  13:33:18  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by SJ</i>
<br />I installed a ball valve just above the seacock. No priming needed now...
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">DID YOU INSTALL IT ON THE SINK DRAIN SIDE??
