 Shore Power to AC
bmelchionda
Initially Posted - 05/29/2007 :  06:55:42  Show Profile
What is necessary to transfer shore power to AC power? I would like to use various AC units at my slip without dealing with an inverter.
Thanks!
'86 Catalina 25 Tall Rig
Response Posted - 05/29/2007 :  07:21:14  Show Profile  Visit britinusa's Homepage
Bryan, get Don Casey's Small Boat Electrics: Excellent information.
Don't try the short cut of just running an extension lead and multi socket outlet.
Basically you'll need a shore power cable, connector somewhere outside, a master switch (preferably with a reverse polarity detector) a distribution switch block (example sw1=Cabin Port Side sw2=Cabin Stbd Side sw3=Battery Charger) and of course 110v wiring to 110v outlets.
Don't skimp on the wire quality, you really do want to use the suggested types in Don's Book, ie. Tinned Stranded wire, the flexibility of the wire is a must.
It's going to cost a couple of boat units, but it will enhance your boat, and keep you safe.
Read the book.
Response Posted - 05/29/2007 :  07:30:50  Show Profile  Visit Frank Hopper's Homepage
I do not understand the question, shore power is alternating current. Did Paul answer your question?
Edited by - Frank Hopper on 05/29/2007 07:32:13
bmelchionda
Response Posted - 05/29/2007 :  08:22:46  Show Profile
Sorry if I was not clear. I'm just looking for an immediate work around to use the shore power with a "connector" of sort to be able run various tools at dock side such as a vacuum, a radio or my laptop.
Response Posted - 05/29/2007 :  08:45:13  Show Profile  Visit britinusa's Homepage
Bryan, luckily I didn't quote the entire book
All you need to use the shore power for power tools/equipment at the slip is an adaptor from the 110v shore power socket at the slip to a regular domestic connector. You can purchase them from stores like West Marine
Although, most folks would suggest using battery powered units, tools do have a high level of attraction to water around your boat... see the thread about lost overboard tools.
Absolutely ensure that the cable does not drape into the water!!!!
<b>Now for the caviat: what you do is your own responsibility, none of us on the forum have any responsiblity for any damage or injury as a consequence of following 'suggestions' given here. But that goes for every post on this site.</b>
Response Posted - 05/29/2007 :  08:46:29  Show Profile
Assuming you don't have a shore power inlet aboard your boat and you are just wanting to plug into a 30A shore outlet, then you'll need a 30A to 15A adapter.
[url="http://www.defender.com/product.jsp?path=-1|328|49758|299260|319692&id=140095"][/url]
(Click on the picture)
bmelchionda
Response Posted - 05/29/2007 :  09:03:19  Show Profile
Understood Paul. Thank you everyone!
Response Posted - 05/29/2007 :  11:35:23  Show Profile
I occasionally use that adaptor with a heavy-duty outdoor extension cord, making sure to wrap the cord around a dock cleat and a boat cleat to keep it stationary and out of the drink. I also tie the cord and adaptor together at the connection. This is not ideal, but neither are corroded shore power receptacles, breakers, and switches. For me, it's the KISS principle applied to very infrequent needs for AC power.
Edited by - Dave Bristle on 05/29/2007 11:36:32
