I'm looking to put a autopilot on my boat. I'm wondering if the ST1000 is large enough? Or I should go to the ST2000? I usually have the boat loaded with lots of "stuff".
Welcome, Steven(?)... I know people here use the ST1000, but some might want to know what kind of sea conditions you expect to be using it in, and whether you have a balanced rudder (with a stepped leading edge) or the earlier, unbalanced one. The key variable is how quickly and with how much force can it make corrections, which has more to do with sea-state and your helm balance (heavy or light weather helm) than with what's in your boat.
Dave, The plan is just to use the autopilot for raising the sail, motoring, and sailing in mild weather. I'll be using it on the Great Lakes, and cruising upper Lake Huron, "North Channel". My boat is # 235 and I think it's the old style rudder. Only sail the rough stuff when I have to.
Since I'm primarily a singlehanded sailor, I use my autopilot, an ST1000, pretty much everytime I leave the slip. I do have a balanced rudder which in conjunction with a balanced sail plan means I have two finger control of the tiller, maybe a few pounds of force required to keep course. (The ST1000 is rated at 125lbs of thrust). Depending on sea and wind conditions, under sail I've found autpilots work best when the apparent wind is abeam and forward, and less so when the wind (or waves) is abaft of the beam.
Under normal usage with a balanced sail plan, the autopilot moves very little, maybe a 1/2" or so either way to maintain course. This video shows my autopilot in action.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by stevena</i> <br />Dave, The plan is just to use the autopilot for raising the sail, motoring, and sailing in mild weather. I'll be using it on the Great Lakes, and cruising upper Lake Huron, "North Channel". My boat is # 235 and I think it's the old style rudder. Only sail the rough stuff when I have to. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I just sold a Contessa 26 that weighed in at almost 7000 lbs. I used the ST1000 on it for eyars with great success. I am planning on transfering it to my "new" 1980 C25.
Don, Do you have any higher resolution photos of your autopilot's attachment? I bought mine used & I'm still trying to figure out the best method of attachment. It didn't come with any attachment hardware, and only has a couple of "ears" on it to attach to. It's an older Navico TP2500. It was only $50 so I figure I can invest a fair amount into it's mount & still be far ahead.
Rita really wanted to know how many degrees of heel you were on, so I inserted a screen shot into AutoCAD & made a rough measurement, about 22° of heel or so. That presumes your boarding ladder is perpendicular to the centerline of the boat fore & aft.
No, I don't have any close ups of my autopilot mount, but it is one of I think three different mounting options available on the ST1000(cantilever).
Yeah, the boarding ladder is fairly perpendicular so your estimation is probably close.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Don: Did you give any thought to mounting your autopilot on the top of the locker cover rather than on the coaming? That is what I am intending to do and just wondered about your set up.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by newell</i> <br />Don: Did you give any thought to mounting your autopilot on the top of the locker cover rather than on the coaming? That is what I am intending to do and just wondered about your set up.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Newell,
If you look closely at the cockpit seat below my autopilot, you can almost makeout three screws where the previous owner had mounted his. I opted for the cantilever mount so I could slide my full length cockpit cushions under the autopilot. Additionally, if I need to tuck something away in the locker, I can open it a few inches to do so.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dlucier</i> <br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by newell</i> <br />Don: Did you give any thought to mounting your autopilot on the top of the locker cover rather than on the coaming? That is what I am intending to do and just wondered about your set up.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Newell,
(David: Thanks for cleaning up my link) <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I had thought about the issue of the cockpit cushions but decided two things: (1). I would not be able to sit on that portion of them when the autopilot was attached and (2) I can probably lay the cushion on the outboard end of the pilot without interfering with its duties. The starboard locker on my boat is so shallow it is almost nonfunctional anyway!
I think if I do it this way I can avoid purchasing any extensions to the "plunger". I might have to use one of the risers on the tiller in order to make the whole thing level....I'll have to see.
Thanks guys for all the information. I'm still looking and trying to decided!! Anybody have info on Simrad TP10. It's cheaper and has a little extra thrust.
I am using the ST1000 and am pleased with it. Does the Simrad offering have a compass? The ST1000 does. Not sure if it is important to you, but that might be a difference.
1. We used Autohelm parts for the bracket on the tiller to hold our older navico tillerpilot.
2. We used the seat, too. Epoxied a square of plywood underneath and then drilled the hole for the pin. Agreed you can't sit there. My daughter, then about ten, made the lightbulb pop on overhead: just scoot the cushion forward and bend it against the back of the cabin - back.
Edited by - Stu Jackson C34 on 06/16/2007 01:18:27
Hi Knotty Cat, Have you had to use your "Auto Compass Calibration" mode or is it accurate enough without doing that. Sitting here at my desk it seems confusing. Guys, Gals, how about the ST1000, does it Calibrate itself?
The thing is I only have 9 days this year to sail and I want to take a new Autopilot out of the box, install it and Go! I'm going to trailer the boat to the North Channel, Little Current Ontario, (500 miles from my house) and do some sailing in that beautiful part of the world. So I'd like something trouble free, if there is such a thing.
My TP-10 is installed in a bronze fitting that is simply epoxied into the Stbd aft locker lid. The tiller mount is an aluminum bracket that is screwed into the bottom of the tiller.
The trick, is the pilot needs to be level with the mount on the tiller. If you use the side of the coaming, you will need a shaft extension and will have a pin sticking up on the top of the tiller.
Here is a picture of the bracket I have. Not sure on the size. I would download the manual for the pilot you are going to buy and make sure you have the accessories you need prior to getting to the boat. You will not find this kind of stuff at your local west marine.
here is a link to a full line of autopilot accessories
