 Whisker pole questions
danc
Initially Posted - 06/26/2007 :  00:00:42  Show Profile
C-25 came with a heavy duty aluminum whisker pole that has a "c" shaped jib end with a roller inside. So it will lay on top of the jib sheet and move along it.
1. Is there some way of keeping it from sliding away from the clew or attaching it so it doesn't slide? Could tie a knot in the sheet an inch from the clew but have never seen that done so maybe there's a reason.
2. It went overboard Saturday and got about half full of salt water before I retrieved it. (Now has a safety line) Should I try to take it apart and rinse it out to avoid corrosion?
Dan Clawson
"Keta" C-25 SR SK
Hull #1901
Seattle
Oscar
Response Posted - 06/26/2007 :  03:08:19  Show Profile  Visit Oscar's Homepage
My jib sheets attach to jib with a simple bowline. (I don't like hardware flapping around on the fore-deck.) I use the whisker pole upside down, and hook it to the loop of the bowline. Nice and secure.
Response Posted - 06/26/2007 :  09:11:31  Show Profile
I assume it is an adjustable pole. Yes, you should take it apart and clean it. Forespar recommends that in salt water environments the adjustable poles be kept inside the boat when not sailing.
Response Posted - 06/26/2007 :  09:49:09  Show Profile
Dan,
I have the exact same pole and have no idea how that end is suppose to be utilized. Any time the sail relaxes the pole is subject to release since there is no locking mechanism like every other pole end Forespar sells. I notice this one is not even listed in their catalog anymore. My latest solution has been to attach a spring loaded clip through the eye, inboard of the pulley, and the clew of the sail but I have not had a chance to try it out yet. For the benefit of those who would like to comment I have attached a drawing of the end which I think is pretty close.
Edited by - Sloop Smitten on 06/26/2007 09:51:36
Response Posted - 06/26/2007 :  10:14:23  Show Profile  Visit Frank Hopper's Homepage
I have always thought of those ends as "dingy" ends, the idea is you can catch the sheet with the end at a point almost perpendicular to the mast and then push the pole on out the sheet, once out then connect the other end to the mast ring; this is all done while centered in the cockpit of a dingy. I believe keelboats should have a locking jaw end and I do have a knot about six inches back from the clew because even a locking jaw will slide back. I think my adjustable Forespar button locker is about 2" diameter, most roller ends seem to be on smaller poles.
stampeder
Response Posted - 06/26/2007 :  10:44:16  Show Profile
Any suggestion on how to straighten a bent one?
Response Posted - 06/26/2007 :  11:47:01  Show Profile
Frank,
The pole I have, and I suspect Dan has, is at least 2" in diameter and probably 2-1/2". Definitely oversized for a dinghy. With our fore stays you cannot go perpendicular to the mast but I have tried it like you suggest and it inevitably falls off the sheets or out of the clew. I was curious if the pulley was there to run along the sheet or be utilized in some other manner. I have done multiple searches on the web to no avail. Might have to contact Forespar directly.
Response Posted - 06/26/2007 :  15:30:32  Show Profile
I emailed Forespar.
<i>"The endfitting is from a whisker pole made before 1975. The jib sheet runs on the sheave. A new latch endfitting to fit your pole will cost aprox. $86.00. It's just an order design."</i>
Not much information regarding the proper rigging of it. My guess is a topping lift would be required to alleviate Dan's problem. Since I have a CDI furler I have a spare halyard so the next time I try to set it I am going to attach the pole end to the lee sheet and run the windward sheet around the fore cleat. Between the two sheets and the halyard I should be able to secure it firmly eliminating any luffing that may occur. Any other idea's?
danc
Response Posted - 06/27/2007 :  00:33:50  Show Profile
Joe, I'll have to try the dual sheet method. I have an extra block and some line to rig a topping lift next time the mast is down. Then no need for an $86 fix.
A couple of things I've heard are that the topping lift does work well and also never stick the end of the pole through the foresail clew cringle or it can get ripped out in a gust.
I have found that having the whisker pole out and the boom on the same side rather than wing-on-wing gets significantly better speed on the same bearing. Haven't noticed anyone else using this technique - maybe my boat is just quirky.
