 Well, I'm feeling a little foolish...
DaveC25
Initially Posted - 06/26/2007 :  13:49:23  Show Profile
So I am certainly no carpenter....
I was trying to fix the new bulkhead ("fix the new bulkhead", that's funny) from where I drilled the chainplate holes in the wrong place. So I mixed up some resin and I dipped in some fiberglass mat and was trying to shove it into the holes. Of course, I was making a huge mess with the resin running down my nice treated wood. After a couple of hours of redoing it and trying to get the resin cleaned up, the light finally switched on in my head. A WOODEN DOWEL!!! So yes, i went and bought some 3/8" wooden dowels, and dipped them in resin and I fixed the problem in 10 minutes after wasting a whole night trying to do it the other way.
Oh well, I'm learning.... :)
Does anyone know whether or not if I take off the bumper strip around the boat if I can access the hull to deck joint there? I was to squirt in some 5200 or other sealer(cheaper maybe) to seal it to prevent water getting in. Also, how do you get the bumper strip off?
DaveC25
1979 Catalina 25 "Pretty Penny" #1166
Palm Bay, Florida
Edited by - DaveC25 on 06/26/2007 13:52:13
stampeder
Response Posted - 06/26/2007 :  16:29:28  Show Profile
All part of the wonderful world of boat ownership.
Welcome to the club.
existentialsailor
Response Posted - 06/26/2007 :  16:55:02  Show Profile
Glad the dowel worked fine. Were it me, I'd have mixed the epoxy with wood flour until it was the consistency of peanut butter. I would have wrapped a couple of pieces of scrap lumber in plastic wrap, laid the bulkhead on one piece, filled the hole and then clamped it all together. Your dowel probably worked better.
Jefffriday
Response Posted - 06/26/2007 :  17:10:51  Show Profile
I recently replaced my bumper strip, it just pulls out of the aluminum channel. I could see the screws holding the channel on, but that was all that was visible. I don't know if pulling the channel off would give you the access you are looking for, (I read your earlier posts about your water leaks) I also doubt that getting an aged bumper strip (read: stiff) back in would be easy , if even possible. Catalina Direct sells new strips for about 110.00 if I recall. If you do it, skip the bucket of hot water they recommend and use a spray bottle with some soapy water in it. That and a mallet, and mine went in fairly easily
DaveC25
Response Posted - 06/28/2007 :  07:49:41  Show Profile
Thanks for the information!
I guess I'll try to access it from inside the cabin, then. I saw the joint here and there inside, but alot of times access appeared to be blocked. Maybe if I take all those wooden trim pieces off inside I can get up in there and squirt the RTV in there.
-DaveC25
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Jefffriday</i>
<br />I recently replaced my bumper strip, it just pulls out of the aluminum channel. I could see the screws holding the channel on, but that was all that was visible. I don't know if pulling the channel off would give you the access you are looking for, (I read your earlier posts about your water leaks) I also doubt that getting an aged bumper strip (read: stiff) back in would be easy , if even possible. Catalina Direct sells new strips for about 110.00 if I recall. If you do it, skip the bucket of hot water they recommend and use a spray bottle with some soapy water in it. That and a mallet, and mine went in fairly easily
glittle
Response Posted - 06/29/2007 :  20:43:13  Show Profile
I have removed and replaced the rub rail on my Catalina 22. You can use a heat gun to "soften" the rubber rail but be careful not to scorce or burn it.
