 Battery Strength
Initially Posted - 06/27/2007 :  07:11:19  Show Profile
Now that I have the solar panel, I can calculate the various loads/drains on the battery and also figure the likely recharging; allowing for inefficiencies, cloud cover etc....my question is - Are there any meters I can use to determine how well charged the battery actually is? So that when I get on-board, I can see how much 'juice' is available?
Many thanks!
Jerry
Response Posted - 06/27/2007 :  07:18:30  Show Profile  Visit DaveR's Homepage
I'm sure there are more extravagant gauges but I just use a cheap voltage meter, and Since I've become comfortable with my solar charger I rarely use that.
Response Posted - 06/27/2007 :  08:13:10  Show Profile  Visit OLarryR's Homepage
Agree the cheapest route that gives a sense of the battery strength is reading the volts off of a voltmeter. Though this does not give a real good feel for the amp drain and when under load. Still, the voltmeter is a good way to get a sense of the battery condition.
Slightly better is reading the voltage off of a solar controller. The controller has the extra benefit that you can see the readings all the time and that is a convenience. It will also indicate when the solar panel is charging or if the battery is fully charged or weak. I use a Morningstar Pro 15M controller.
Response Posted - 06/27/2007 :  09:18:35  Show Profile
Thanks guys - great advice!
Bill Arden
Response Posted - 06/27/2007 :  09:33:08  Show Profile
Here's some information I found from this site:
http://www.solarnavigator.net/battery_charging.htm
While the chemical thermodynamics people among us may bicker, I'd guess this is close enough for most of us. I use a similar chart for the solar charger on Prana.
State of Charge 12 Volt battery Volts per Cell
100% 12.7 2.12
90% 12.5 2.08
80% 12.42 2.07
70% 12.32 2.05
60% 12.20 2.03
50% 12.06 2.01
40% 11.9 1.98
30% 11.75 1.96
20% 11.58 1.93
10% 11.31 1.89
0 10.5 1.75
Bill Arden
Response Posted - 06/27/2007 :  09:35:39  Show Profile
One more note: These voltages are measured with no load on the battery (i.e., everything turned off), and no charger operating. My solar charge controller is smart enough to vary the charging voltage, so all I read when it's connected is a ramping voltage that constantly varies.
Bill Arden
Response Posted - 06/27/2007 :  09:44:08  Show Profile
Oh, @#$%
Sorry about the formatting of that table. I tried to do it with spaces, and didn't realize the editor would kill all the extra spaces.
The three column headings are "State of Charge", "12 Volt battery" and "Volts per Cell." The left-hand column ranges from 100% down to 0; the middle column ranges from 12.7 (at 100%) down to 10.5 (at 0%); the right-hand column ranges from 2.12 down to 1.75.
Hope that helps!
Response Posted - 06/27/2007 :  11:47:00  Show Profile  Visit OLarryR's Homepage
Bill,
I agree the solar controller measures the ramping voltage...except when the sun is not out or at a unfavorable angle. When the sun is not out or at a unfavorable angle, the controller (or at least mine) then reads the battery voltage without charging going on. If I start the motor and the sun is overhead, the solar amps on the controller goes to zero since the controller prevents the current going to/from the panel but then the controller reads the ramped up voltage from the motor charging....which i agree is not the actual battery voltage. The ramped up voltage is the voltage above the battery voltage needed to get the amps from the panel or the motor into the battery.
Turk
Response Posted - 06/27/2007 :  17:44:28  Show Profile  Visit Turk's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jerlim</i>
<br />Now that I have the solar panel, I can calculate the various loads/drains on the battery and also figure the likely recharging; allowing for inefficiencies, cloud cover etc....my question is - Are there any meters I can use to determine how well charged the battery actually is? So that when I get on-board, I can see how much 'juice' is available?
Many thanks!
Here is a link to a voltmeter panel I bought for my batteries for just this reason. Inexpensive and works great. I added a cheap monetary push button to view the voltage. Mounted it near my electrical panel.
http://www.marteltesttools.com/products.php?cat=113& action=detail& id=69
Bubba
Response Posted - 06/27/2007 :  18:48:18  Show Profile
I have the same volt meter. Since it only draws 3mA max, I didn't put a switch on it. It's on when a battery is switched on.
SEAN
Response Posted - 06/27/2007 :  18:54:54  Show Profile
you could get a battery moniter , xantex has one for $300 . i dont know if you want to know that much !! . But there nice tells how much amps are flowing in or out . And tells a % percentage of battery . they say not to let the battery go below 50 %
It also can calculate time left in hours or minutes .
Tom Potter
Response Posted - 06/27/2007 :  20:59:16  Show Profile
A lot of the newer depth finder/chart plotters units have "data overlays" which allows you to put the units data on the screen you have selected to use of the finder/plotter. I have my Lowrance set up to show the plotter screen when I turn the unit on, but in the corners of the screen is the water depth, boat speed, battery voltage, and the time.
Edited by - Tom Potter on 06/27/2007 21:42:48
atgep
Response Posted - 06/27/2007 :  23:05:51  Show Profile
I was very surprsed to find my Eagle chartplotter lacking the Voltage reading. It is available for all the lowrance products but not their stepchild brand, Eagle. The Eagle is the cats meow otherwise and costs less.
I have no problem with the batteries up here in the PNW. The motor is almost aways on!
Tom.
