 Keeping Pop Top up
dnorth
Initially Posted - 07/04/2007 :  18:40:43  Show Profile
How to you keep the pop top up?
I was out clean my boat and decide to put up the pop top. I have never had it up before. It would not stay. I do have a boom vang, but I loosend it and with just a few lines between the top and the mast it would not stay up.
David North
Catalina 25, Swing Keel, 1977, Hull #6
Edmond, Oklahoma
atgep
Response Posted - 07/04/2007 :  19:19:19  Show Profile
There is a key that holds the top up. It sits in the sail-slot and slides up to catch the top.
It also helps to have everything out of the way between the mast and poptop. You could use a 2x4 cut to the right length on each side of the top for now.
Tom.
Response Posted - 07/04/2007 :  19:19:26  Show Profile
With one of these...
Catalina Direct $26.70
[url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&Product_ID=318"]Pop Top Mast Lock Assy[/url]
ddlyle
Response Posted - 07/04/2007 :  21:48:24  Show Profile  Visit ddlyle's Homepage
I use a stout bungee from the top of the forwardmost (pop-top) support down to the base of the mast. The little key-thingie usually drops down the slot on my boat, so the bungee works better for me.
Response Posted - 07/04/2007 :  22:28:43  Show Profile
The top should lean forward a little against the mast. No lines should be between the top and the mast. The sliding lock is only intended to prevent an accidental fall due to wave action or jarring of the top, but won't work if a line is between the top and the mast. An additional restraint is a good idea in case the lock slides down. Is there any evidence that somebody repositioned the struts, either on the cabintop or on the pop-top?
Response Posted - 07/05/2007 :  10:16:49  Show Profile
I have never trusted that inadequate lock. I ease the vang, lift up the pop-top and put a length of 2 x 4 (notched at each end) under it just aft of the regular lifts. It's solid enough to (almost) walk on!
Response Posted - 07/05/2007 :  12:18:57  Show Profile
Gotta say, the pop-top mast slot lock has always worked very satisfactory for me. It's important to tighten the thumb screw, but after that no worries!
Edited by - jerlim on 07/05/2007 12:19:44
Response Posted - 07/05/2007 :  12:37:22  Show Profile  Visit Frank Hopper's Homepage
<br />With one of these...
They also sell a replacement knurled knob to replace the nylon one, I recommend the upgrade.
Response Posted - 07/05/2007 :  12:39:33  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jerlim</i>
<br />Gotta say, the pop-top mast slot lock has always worked very satisfactory for me. It's important to tighten the thumb screw...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I used a wing-nut for better tightening. A toothed lockwasher might not be a bad addition. Also worthwhile is Catalina Direct's pneumatic strut kit--I think there's one listed in the Swap Meet.
bear_tm4
Response Posted - 07/05/2007 :  21:43:18  Show Profile
I use the pop top mast lock, as well as invested in the lift shocks from CD, WOW what an improment, makes lifting the whole thing nice, and now I dont mind doing it half as much as I did in the past, so I would recomend it if you plan on using your pop top more offten, its worth it in my book. If you check my post you will see a pic or two with it up....
Cheers
dnorth
Response Posted - 07/05/2007 :  22:13:24  Show Profile
Thanks for your answers. I am glad I am not going crazy. I will have to get one of those locks. As alway you guys have all the answers for those of us with less experience.
atgep
Response Posted - 07/05/2007 :  23:20:32  Show Profile
A couple of things about the pop top lock.
You will need to drop the mast to put it in the sail slot unless you can get it into the cutout for the main.
When lowering the mast with the lock in place, dont leave it at the bottom or it can grind the deck when the mast is lowered to the rear. If it is too high, it can grind on the poptop edge.
One more "oh by the way"
The lock is more than enough to keep the top up.
Tom.
Response Posted - 07/06/2007 :  07:46:23  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">You will need to drop the mast to put it in the sail slot unless you can get it into the cutout for the main.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Mine easily went in and out of the mast gate. (I believe CD suggests lowering the masts when installing the struts to make it easier to fully preload them.)
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">The lock is more than enough to keep the top up.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I essentially agree--however, if one little boat wake or human error ever causes the top to fall, somebody or something could be badly hurt. The struts should soften the blow (but don't take the place of the lock).
One more thing: I never, <i>ever</i> sailed or motored with the top up.
Response Posted - 07/06/2007 :  08:19:49  Show Profile  Visit DaveR's Homepage
My boat didn't come with the p/t lock, so I ordered one and it didn't fit in the sail slot, but I couldn't see dropping the mast for that so I put it to the grinder (lightly) and it slipped right in!
dnorth
Response Posted - 07/06/2007 :  21:57:41  Show Profile
I was out on a sail tonight and what do you know, I have a pop top lock installed on the mast. Thanks again for the help in knowing what to look for.
stampeder
Response Posted - 07/09/2007 :  23:45:46  Show Profile
AHA!!!
I have one of those pop top locks and I thought it was a broken mast track cleat. Finally, never throwing anything away finally comes in handy.
To date, I've been using a dock line to keep my pop-top in place. I loop the line around the mast and both of the struts - this gives me somewhere to hang things to dry.
Response Posted - 07/11/2007 :  15:01:01  Show Profile
No one has mentioned it yet but there is a kit from CD that makes raising thepoptop a lot easier. It uses gas struts. I had one on my C22 and it made a world of difference.
KiteKraemer
Response Posted - 07/19/2007 :  21:30:17  Show Profile  Visit KiteKraemer's Homepage
Nauti, Do they have them for the 25? The pop top is MUCH heavier on the 25 than the 22. CD is redoing their site and I can't seem to find it. Does anyone know where to get a power lift for the pop top? I noticed one vessel (cat 22) for sale had a power pop top. ??? I didn't get a reply upon my inquiry. Gas struts would be really nice, I can barely lift the top myself.
-jeff
Response Posted - 07/19/2007 :  22:49:32  Show Profile
CD has a kit for the C-25. Reports I've heard say it reduces the apparent weight by 1/2 - 2/3.
KiteKraemer
Response Posted - 07/19/2007 :  23:26:48  Show Profile  Visit KiteKraemer's Homepage
Cool! I'm all over it! Their website under const. has no search function!
I'll call them on the tele. Thanks Sarge!
Response Posted - 07/20/2007 :  09:37:06  Show Profile  Visit Frank Hopper's Homepage
CD is short for http://www.catalinadirect.com/
Response Posted - 07/20/2007 :  10:06:40  Show Profile  Visit Champipple's Homepage
My vang has snap shackles on either end, I used to detach the boom end, raise the top, then run the vang around one of the posts and take it back to the mast or the boom and snug it up. - it provided that extra peace of mind
Response Posted - 07/20/2007 :  10:08:27  Show Profile
Try this
http://www.catalinadirect.com/index.cfm?fuseaction=product.display& Product_ID=612
Response Posted - 07/20/2007 :  10:09:10  Show Profile
It's on this page: (The C-250 guy beat the st!nkp*tter posting a C-25 answer.)
http://www.catalinadirect.com/index.cfm?currentpage=2&fuseaction=category.display&category_id=37&sort=name
Edited by - Dave Bristle on 07/20/2007 10:13:33
ricmon99
Response Posted - 09/10/2007 :  09:47:27  Show Profile
Can anyone tell me what the total length of the cylinder and piston is when the schock is fully extended....also what the opening size with the top up from the bottom of the poptop to the top of the cabin roof.....would like to incorporate this lift into my Venture Newport 23....thanx
Rick
Response Posted - 09/10/2007 :  11:14:05  Show Profile  Visit Frank Hopper's Homepage
You will find all of the parts you need here...
[url="http://stores.ebay.com/Great-Lakes-Skipper-LLC_Deck-and-Cabin-Items-Hatches_W0QQcolZ2QQdirZ1QQfsubZ4QQftidZ2QQpZ10QQtZkm"]Great Lakes Skipper[/url]
they have lots of different lengths and fittings, however I think the Catalina Direct ones are rated at 90 pounds. A Catalina 25 poptop is a seriously heavy item.
