 a frame
scut941
Initially Posted - 08/15/2007 :  11:27:57  Show Profile
was there a previous post for the specs for an a frame construction under technical tips?
if so does anyone have it?
thanks
jason
jason glasstein
stampeder
Response Posted - 08/15/2007 :  12:45:23  Show Profile
there are many many posts regarding the A-Frame.
I built one per the specs in the technical tips section. I have now abandoned the A-frame because I think it unnecessary.
The admiral and I raise the mast easily by ourselves. There is a recent post that discusses this.
Here is the link to the technical section, at the bottom is the A-Frame that I built and used. http://www.catalina-capri-25s.org/tech/tech25/bearsad1.asp
IMHO, best piece of equipment is the gudgeon mounted mast crutch that elevates the mast. From the crutch I walk the mast forward while the admiral hauls in the slack on a safety line (usually the jib halyard) the mast on a standard rig weighs 60LBs. Main thing is to know where all the rigging is supposed to be. Keep the rigging tangle free, and its a do-able job for two people.
Edited by - stampeder on 08/15/2007 12:58:33
lcharlot
Antigua and Barbuda
Response Posted - 08/19/2007 :  23:06:00  Show Profile
Lifting the mast by hand on a Standard Rig is do-able if you have at least one helper, but, if your boat is a Tall rig, or you are trying to do a mast raising alone with no helpers, you really need either a gin pole or A-frame. The Tall Rig mast is not only three feet longer than the Standard, it's cross section is 1/2" larger in both width and depth, and the wall thickness of the extrusion is 1/32" more. This makes the Tall Rig mast substantially heavier than the Standard, I'd guess at least 85~90 pounds - it's approximately the size and weight of a C-27 mast. I use an A-frame made of two 12' long 2x4's, attached to the middle pair of stanchions at the base. 2x4's are awfully heavy, but they are a lot less expensive than 2.5" x 1/8" wall aluminum tubing, which is what I would prefer to use if I could find two 12' long pieces of it at a reasonable price. Your biggest concern is to prevent sideways motion of the mast while it is going up or down; if you are single handling this operation, you should modify your upper shrouds to a "Huntington Rig" configuration. This modification keeps the uppers under slight tension (no slack) during the whole travel of the mast so it can't sway off-center while you are lifting it. There should still be examples in the Tech Tips section of this web site on how to do a Huntington Rig modification.
Ed Montague
Response Posted - 08/23/2007 :  23:27:22  Show Profile
Before I put a roller furling 150% on my standard rig I could lift the mast by hand with help using the main sheet and jib halyard attached at the bow. It took 3 of us, one lifting at the back and clearing lines, me lifting, and the third person pulling the sheet thru the main sheet blocks at the bow. Once I put the roller furler on (I leave the sail on when I trailer,(I know that will start another discussion.) the weight of the mast was far too much for me to lift, even with 3 people. I built an A-frame as discribed in the tech tips and now my wife and I step and unstep the mast by ourselves. It is amazingly simple. With the help of a mast crutch on the stern we can get the mast up in about 30 minutes from stopping at the ramp to being up. Get an A-frame even if you don't have a roller furler, nothing will ruin a vacation or weekend faster then straining your back or worse.
