 Paint or gelcoat?
rafort
Initially Posted - 08/25/2007 :  09:40:44  Show Profile
I recently purchased an 86 Catalina 25. The previous owner had painted topsides and paint was oxidized. Upon removing the paint I discovered the original gelcoat appears to be in good condition with a few dings and scratches filled with epoxy prior the the paint job. There appear to be a few small patches where previous sanding burned through the gelcoat. Should I dig or dremel out the epoxy from the dings and fill with gelcoat then wet sand and compound topsides or am I better off priming and painting with a two part polyurethane?
Response Posted - 08/25/2007 :  09:58:28  Show Profile
I am not by any means an expert, however I have owned a number of older fiberglass boats and have a bais toward maintaining the original gel coat as long as is reasonably possible. That being said, if I were you I would try to buff out a small representative section and see if the gel coat still shines up. If so, I would try to maintain what was there. If the gel coat in your test section looks drab after buffing, I would proceed toward some form of paint finish. In either case it really depends on the amount of work/time/money vs. how you think it looks at the end.
All the best
Response Posted - 08/25/2007 :  11:15:48  Show Profile
I've had good luck filling gouges with one-part gelcoat patch (from a tube), wet-sanding, and polishing... I'm not so sure about those "burned through" areas. But painting topsides always seems to lead right back to where you just were--stripping the chipped, oxidized stuff off.
saribella
Response Posted - 08/27/2007 :  14:43:45  Show Profile
Save yourself the headache. Start with Interlux Prime Kote and then overcoat with the Interlux Bright-sides. When properly applied, it looks great and is very durable.
rafort
Response Posted - 08/28/2007 :  08:15:51  Show Profile
I appreciate the input. Upon filling gouges with gelcoat, I discovered original gelcoat layer was very thin and over a blue base. It's back to the Interlux system.
