While doing some straightening, I decided to open up the access port located in the forward storage cubby at the v-berth. (don't know why the PO used a clear cover, but he did)...
I then noticed this device:
sorry for the fuzzy images...
It appears to be a cast piece. I'm not sure where the wire goes to, although I will check behind the circuit panel this weekend. What is the apparent wire handle for?
If it's a depth gauge, there is no read out device, unless it somehow connects to the Garmin 162 Plotter...I'm stumped.
It is a torpedo tube. Some models of the C25 were equipped with these devices in an attempt to help eradicate jet skis. The weapons were banned in the early 1990's and most were removed at that time. Whatever you do, don't pull the wire handle.
Much as I'd like the deck cannon sometimes, my best guess is it's an old depth sounder transducer. I found a similar "surprise" tucked away on my San Juan 21. Saw the wires first when I opened the access panel, couldn't figure out what it could be, poked around a bit and located the through-hull, then went outside (it was on the trailer at the time) and took a look. Sure enough, there was a painted over transducer just forward of the keel that I'd never noticed before.
Good spot for a depth sounder... so the alarm sounds milliseconds before you hit the rock. A flat disk outside is the clue. But it appears to predate the kind that integrate with your GPS. Follow that black wire...
Looks to be a fishfinder to me. It's glued to the hull so there won't be any bubbles under that white plate. Forward on the hull so that it can "look" forward and maybe see fish. My guess is that the PO cut the wire (or disconnected it), stuffed the connection underneath somewhere near the place the fishfinder module was mounted, and took the fishfinder off the boat to be placed on another. Since the transducer was permanently planted, a new one probably was located for the next boat. ....but I do like the torpedo tube idea...it would come in handy while entering and leaving Mission Bay on our ocean sails
