Anybody consider installing an electronic battery monitor? Anyone use a simple voltmeter to determine state of battery charge? The monitors seem quite expensive and I am not sure they are really necessary for the 250 but since I do not have any means to charge away from the dock (no alternator yet) I would like a reasonable ( <<< $$$$) method to judge remaining energy.
I use a 12 Volt digital voltemeter that plugs into the lighter receptacle on my 250. I have compared the readings with my VOM and it is pretty accurate. You can buy it at Walmart for under $15.00.
I also use a DVM in the lighter receptacle; do you test under load or with everything off? What voltage levels do you use to consider 'full' and / 'empty'?
I only check the voltage when the battery is at rest. If you check it under load, the reading is going to be lower because of the amp draw. I have a Waeco portable fridge/freezer and 3 size 29 deep cycle batteries. I estimate my daily amp ussage at about 100 amps a day or about one third of my battery capacity. I have a copy of this chart next to the panel so I know when its charging time. Whenever possible, I will charge when the batteries drop down to about 12.3 volts. State of charge chart for 12 volt batteries: • 12.70 volts 100% • 12.50 volts 90% • 12.42 volts 80% • 12.32 volts 70% • 12.20 volts 60% • 12.06 volts 50% • 11.90 volts 40% • 11.75 volts 30% • 11.58 volts 20% • 11.31 volts 10% • 10.50 volts 0%
Cavitating, how do you charge your batteries on a cruise? The typical outboard would take a long time to charge that much battery capacity...do you have solar panels, or...?
I am in central Florida and most of what I do is cruise to a nearby island where I spend the night and come back late the next day. At night, during the hot and humid Florida summer, I will run a Honda 2000 generator that powers a window unit air conditioner and a 20 amp Charles battery charger. During the cooler days, sometimes my power consumption will not require that I run the generator at all and will recharge at the marina. I have being doing this for many years on a Hunter 240 that I used to own and it works for me. After being in the sun all day the cool air and low humidity makes a difference. The admiral will not do it any other way. I know that for some of you the extra weight and noise is a no-no but for me is a way of living.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Cavitating</i> <br />I use a 12 Volt digital voltemeter that plugs into the lighter receptacle on my 250. I have compared the readings with my VOM and it is pretty accurate. You can buy it at Walmart for under $15.00. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
what department at Walmart did you find it it? Their web site does not show one available.
You could buy a AVO cheaper than this, but this is pretty cool if you like messing about with erectronics. <center> [url="http://www.autospeed.com/cms/A_2082/article.html"]DIY LED VoltMeter Panel[/url]
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Cavitating</i> <br />You will find it where they have the 12 volt batteries in the automotive department. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I made a trip to wally world today and found the digital voltemeter that plugs into the lighter receptacle right where you say it would be. Picked it up for $16, works great.
I have the traditonal red-green-amber battery conditon meter that has never worked. I tried connecting it directly to the battery posts but got no reading on the meter. I have also tried connecting an analog meter the same way, again with no response.Is there something special I need to be doing to get this thing working?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tompotter</i> <br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Cavitating</i> <br />You will find it where they have the 12 volt batteries in the automotive department. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Thanks for the idea. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
It is fairly accurate, inexpensive and easy to use. I am glad you found it!
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by aeckhart</i> <br />I have the traditonal red-green-amber battery conditon meter that has never worked. I tried connecting it directly to the battery posts but got no reading on the meter. I have also tried connecting an analog meter the same way, again with no response.Is there something special I need to be doing to get this thing working? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Make sure you have the leads plugged into the correct jack on the analog meter (if, as on many meters, there are two). You want to measure volts (potential)--not amps (current flow). Beyond that, try the screwdriver test--maybe the battery is dead!
I just bought a bunch of stuff to do a winter electric project to add outlets, 2 batteries, new smart charger, etc. Got a Xantrex Link 10 monitor which claims to be a "fuel guage for your batteries" and does things like show amp draw, remaining amps, remaining time before charging needed, etc. Probably more than I need to know but I do rely on the electric system for navigation and comfort.
