 Admiralty Forum
 Winterizing
Admin
Forum Admin
Initially Posted - 09/16/2007 :  08:15:16  Show Profile  Visit Admin's Homepage
For many of us in the north, not having a C-25 with an outboard means we have more to do when we put it away for the winter.
What do you do?
Response Posted - 09/16/2007 :  21:25:03  Show Profile
Huge topic--there are whole books on it (as you no doubt know). Few people here know the answers, and anyone who does probably would get Carpal Tunnel Syndrome typing it.
Enjoy your yacht!
Admin
Forum Admin
Response Posted - 09/17/2007 :  08:12:11  Show Profile  Visit Admin's Homepage
True Dave - but there are simple lists...
Fall -
Run antifreeze through all freshwater systems,
change oil,
Change Oil Filters
Antifreeze through Raw water pump
Antifreeze through Head system
Spring
change the Ethylene Glycol
Change Impeller
Change filter in Primary and secondary fuel Line
Response Posted - 09/17/2007 :  11:35:36  Show Profile
Here's a summary from Don Casey...
<b>Outboards</b>
<b>Freshwater flush</b>
Use a flushing attachment, or run the outboard in a tank filled with clean water.
<b>Empty fuel lines and carburetors</b>
While the engine is still running, disconnect the fuel line from the engine. When the engine dies, the fuel delivery components will be empty, preventing gums from forming in the stagnant gasoline and clogging lines and jets or injectors.
<b>Fog the carburetor intake(s)</b>
Before the engine runs out of fuel, spray fogging oil into the carburetor(s). Fogging oil is an anticorrosive that will protect the internal surfaces of the carburetor and the cylinders. Typically the engine will run rough just before it runs out of fuel. As that happens, give the carburetor(s) a heavier shot of fogging oil to make sure internal surfaces are fully coated.
<b>Drain cooling passages </b>
Disconnect the flush attachment or remove the motor from the flush tank. With the motor upright, let all water drain out of the pick-up. Open drain plugs (if any--see your owner's manual) to empty the powerhead and intermediate housing. Crank the motor a couple of times by hand or "bump" it with the starter to empty the water pump. If the motor will be exposed to freezing conditions, it is essential that no water remains inside.
<b>Fog the cylinders</b>
Remove the spark plugs and spray fogging oil into the holes to coat the interior surfaces of the cylinders. Rotate the flywheel a few turns to spread the oil on the cylinder walls. While the plugs are out is the time to check them and regap or replace as required. Reinstall the spark plugs.
<b>Lubricate linkages and the electric starter drive mechanism</b>
Clean all pivots and visible gears and protect them for the winter with oil or grease, as specified in your owner's manual.
<b>Drain and refill gearcase</b>
Use lubricant specified in your owner's manual. Fill oil tank
This will prevent condensation from forming inside the tank.
<b>Touch up damaged paint</b>
Mist-coat powerhead with an anticorrosion spray
<b>Drain fuel tank and supply lines</b>
Starting your engine in the spring with old gasoline is an invitation to problems. Manage the last few weeks of your boating season to leave your fuel tank(s) close to empty, then drain the fuel that remains. Use it in your snow blower or burn it in your car, but leave gasoline tanks and lines empty.
<b>Stabilize the fuel</b>
Some boaters prefer to store the tanks full to minimize the potential for condensation. I find a cupful of water in the tank in the spring a lot smaller problem than 50 gallons of bad gasoline, but if you want to leave the tank full, pour in an appropriate amount of gasoline stabilizer to combat the formation of passage-clogging gums.
<b>Clean and liberally lubricate propeller shaft</b>
The off season is the perfect time to have your prop(s) serviced. If the engine will be stored on the boat, take the prop(s) home to discourage theft.
<b>Store upright</b>
Laying the engine down risks water draining where it shouldn't. An engine stand is easy enough to cobble together.
<b>Inboards</b>
<b>Change coolant</b>--fresh-water cooled engines only
Coolant loses its anticorrosion properties over time. Replacing it every year with a fresh 50-50 mix protects the inside of your engine.
<b>Change oil in engine and transmission</b>
First take the boat out for a ride to get the oil hot and contaminants in suspension. (This also distributes the fresh coolant throughout the engine.) Replace the oil filter.
<b>Top-off fuel tanks and add biocide</b>--diesel engines only
Keeping the tank full inhibits condensation, a serious problem for diesel engines. Treat the fresh fuel with a biocide to retard bacteria growth. A stabilizer is unnecessary unless you expect to run the engine during the winter since the paraffin that precipitates out will be reabsorbed by the fuel when warm weather returns.
<b>Run engine out of fuel</b>--gasoline engines only
Shut off the fuel supply and let the engine run until it stops.
<b>Fog the intake</b>--gasoline engines only
While the engine is running, remove the flame arrestor and spray fogging oil into the air intake. Give it an extra heavy shot just as the engine starves and dies.
<b>Drain fuel tank and supply lines</b>--gasoline engines only
Adding stabilizer is an alternative but less effective way of avoiding engine problems in the spring resulting from stale gasoline.
<b>Flush raw-water circuit</b>
If you have a fresh-water flush connector, use it. Otherwise, close the intake seacock and disconnect the hose on the outlet side of the raw-water pump. Disconnect the cooling-water discharge hose from the exhaust manifold or riser. Run fresh water into the discharge hose to back-flush raw-water passages and rinse out salt deposits. You can extend the disconnected pump hose outside the boat or let the bilge pump handle the flush discharge.
<b>Protect raw-water passages</b>--raw-water cooled diesel engines only
The raw water circuit must be drained to prevent freezing, but air exposure promotes corrosion. Reconnect the water-pump outlet hose. Insert a funnel into the disconnected discharge hose and pour a 50-50 mix of propylene glycol antifreeze into the funnel until the hose will not accept more. Allow the mixture to remain inside the block for several minutes, then open all raw-water drain plugs and drain the engine. This treatment leaves behind a layer of corrosion protection on the water-jacket, and it freeze-protects any water that might be harbored in low spots inside the engine.
This treatment is also applicable to protecting the heat exchanger on a fresh-water cooled engine.
<b>Remove raw-water impeller</b>
Antifreeze swells some rubbers, so rinse the extracted impeller as a precaution. Some grease the impeller and reinstall it. My preference is to leave it out until spring so the vanes don't take a set.
<b>Fog cylinders</b>--gasoline engines only
Remove the spark plugs and spray fogging oil into the holes. "Bump" the starter to spread the oil on the cylinder walls. Regap or replace plugs, as required, and reinstall.
<b>Fog intake</b>--diesel engines only
Spray fogging oil into the intake manifold and turn the engine over slowly by hand to draw the oil into the cylinders and spread it. Do not use the starter, even with the stop control pulled out; the engine can start on the fogging oil.
<b>Drain muffler canister</b>
The less moisture the engine is exposed to, the less corrosion will occur.
<b>Degrease, derust, touch-up</b>
Maintain all painted surfaces to keep corrosion at bay.
<b>Grease control cables</b>
Extract control cables from their housings and coat them with grease. If you cannot remove them, tape an oil-filled bag tightly around the high end of the housing; the oil will work its way down the cable. Lubricate linkages and pivots.
<b>Coat unpainted parts with an anticorrosion spray</b>
<b>Seal all engine and tank openings</b>
Keep moist air from getting inside your engine and tanks. Seal air inlets, crankcase and transmission breathers, exhaust outlets, and tank vents. Fabricate caps from plastic containers and tape them in place with plastic tape to create an airtight seal.
<b>Tighten stuffing box</b>
If the boat will be stored in the water, tighten the stuffing box to eliminate all dripping. Tag it to remind you to loosen it in the spring.
Dave's note: Sealing fuel tank vents is not recommended by all "experts"--some say fuel expansion could cause problems. Also, there's a huge debate over draining versus filling and stabilizing gasoline tanks. (Filling diesels is OK, with biocide added.) Due to practical issues, I'll probably have to fill my tank (gasoline) and add plenty of stabilizer and Startron to it.
Edited by - Dave Bristle on 09/17/2007 11:36:37
