From what I've read, I'm really attracted to the stability offered by the wing keeled 250. I really want a trailerable 250 and understand the waterballast is much easier as far as trailering. I was looking for comments on who might have the wing keel on 250 and how much more difficult it is as opposed to the water ballast. Trying to look at all the angles before settling on which to purchase.
One other difference between the two is cabin height, the WK has another 10" of head room due to the lack of a water tank.
I get 5'6" standing head room in my 250K, a very welcome difference from the 4'5" I had with my C22.
As Arlyn mentioned, if you are primarily trailering then the WB will be easier to trailer due to the fact that it's 1,000 lbs lighter and easier to launch. With the additional height of the keel you will either need steeper launch ramps or a rope launch. A rope launch means that you add a long section of heavy duty rope between the trailer and the tow vehicle. I have never tried it. I think you need the trailer jack lowered to provide forward balance for the boat. That might be dicy with some launch ramps. Further more, a rope launch is tricky when you have any kind of current or wind blowing the back end of the boat around. Having another person around to help might be advisable. In any case, launching a WK regularly will be a bit more complicated.
If you are near water and plan to sail regularly then having the boat in a slip while more expensive will greatly increase your sailing time. Launching the boat takes time, it's not something that should be hurried. Once you get really good at it you can expect to spend between 1-1.5 hours between launch and haul-out everytime you go sailing. If you are a weekend sailor like I am you might decide that having her in a slip is worth the extra dough.
If that turns out to be the case then the WK is the way to go, additional stability on the water and more standing head room.
