I'm storing the boat in the backyard this winter and I need to know the right stand size for a 1988 C25 fin keel. My guess is the stand that adjusts 36-54 inches but now I'm not so sure. The boat transporter says the keel will be set 20" off the ground
Depending on the unit cost of your jackstands (times 6), and the equally higher risk of using improperly positioned/stationed jackstands, you might be wise to investigate the availability and cost of a steel cradle. the specs for a cradle are in the tec
The yard put my fin keel on a support 2 cinder blocks high with a 2x8 on top, and surrounded it with 5 stands (one with a V at the bow). That puts the bottom of the keel something like 18" up. The stands are no more than a foot below the waterline, so t
Seems like the small stand (adjusting 36-54")is the way to go. I checked out a boat in the next yard - looks like the identical hull and the stands were around 41-42" with the keel blocked 18" off the ground. Thanks for the help.
Don't forget to get a length of chain to secure opposing stands together. Most stands have a chain slot welded into the base for this purpose. If you don't have the chain, the first big breeze and the stands slip and the boat tips over on it
