OK, enough with association politics. Back to the boat!
We discovered that access to the V berth storage was severely limited by the fact that the storage cover board is cut port-starboard while the cushions are split fore-aft. You basically have to remove everything to get to the big storage area down there.
Here is the factory cover:
I read about the mod on Arlyn’s web site and basically did what he did. Hey, the guy has already done every C250 mod!! I used ½” birch-faced plywood. I used the old cover as a template to a large piece of heavy paper. Then I cut out the form and folded it in half fore-aft and then cut along the fold. Voila, the new templates! Surprisingly, the two halves are NOT mirror images of each other. I then varnished the wood, three coats, and added a stainless steel continuous hinge held in place with 30 stainless steel screws. Then I folded the unit over and drilled a 1” hole for opening and carrying just as Arlyn suggests. Great tip.
Here is the cover:
Here is the cover folded over:
Here is a shot showing the ease of carrying the cover:
We intend to use the storage area for the shore power cables, poptop cover, extra anchor and rode and mast raising equipment (working on a gin pole mod for on-water mast handling). This storage space can now be a functional part of our cruising setup.
