 deck light
coldducks
Initially Posted - 02/09/2008 :  11:13:55  Show Profile
i need to replace the deck light. does anyone know what type of bulb is used on a 99wk. thanks
COLDDUCKS
FANTASY #409 C250WK
Response Posted - 02/09/2008 :  22:44:35  Show Profile
My 2000 uses a West Marine MR16 Xenon Bulb W/Len, trade #881220, Volts:12, Watts:20, Amps:1.67
It says model 303257 on the box
The WM bulbs listing in the catalog drive me crazy but I believe it is WM# 8646630
Edited by - Nautiduck on 02/09/2008 22:58:20
coldducks
Response Posted - 02/10/2008 :  09:14:43  Show Profile
thanks randy. I knew someone here would know the answer. I know what you mean about the wm numbers.
Tom Potter
Response Posted - 02/10/2008 :  10:03:29  Show Profile
Its going to depend on your light maker, my deck light is made by Aqua Signal and has a small 20 watt halogen bulb. Somewhat different than Randy's. It is just a single bulb with no built in "reflector". Bulb - Aquasignal 90470-7.
Edited by - Tom Potter on 02/10/2008 10:30:37
americanrascal
Response Posted - 02/10/2008 :  11:37:02  Show Profile
Just pulled mine (2001 WK) to clean off the wasp nests while the mast was down. Looks exactly like the one Randy has displayed.
Joe
Tom Potter
Response Posted - 02/10/2008 :  11:59:08  Show Profile
One other note, be careful handling the halogen bulb you want to avoid touching it with your bare hands. The oils from your skin will decrease the life of your bulb. Use a clean rag or gloves to install it. If you do touch it wipe it off to remove the oils.
coldducks
Response Posted - 02/10/2008 :  19:14:48  Show Profile
thanks guys, i will buy both. i sure dont want to go up that mast twice!!
Turk
Response Posted - 05/04/2008 :  08:11:01  Show Profile  Visit Turk's Homepage
I just noticed that mine needs replacing also. I have the halogen spot like Randy. Is there a cover under the bulb on the fixture or is it open? Mine does not have a cover and I'm not sure if one was there or not. Also, what holds the bulb in? Does it just press in?
Response Posted - 05/04/2008 :  08:50:01  Show Profile
Turk,
I have a C25 so not sure it the fixture is the same but mine does not have a cover under the bulb.
SEAN
Response Posted - 05/05/2008 :  18:35:26  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Does it just press in?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
mine does .
my sail hit it last year i think i saw a clear plastic cover fall off the boat .
I never replaced the plastic just the bulb its been fine so far , the bulb never fell out .
