 Hole sizes
JohnMD
Initially Posted - 03/03/2008 :  12:28:37  Show Profile
Hi all. I'm going to be drilling some holes inside the boat to hang some curtains. What size drill bit should I use for a #8 screw? 9/64, 1/8??? Thanks. Wish me luck.
Response Posted - 03/03/2008 :  13:37:49  Show Profile
#8 Screw
Soft wood - use 5/64"
Hard Wood - use 3/32"
If in doubt start with the 5/64" or 1/16". You can always drill a hole larger if the screw is to tight. Fiberglass is hard so 3/32" might be closer to what you need.
http://www.santafefasteners.com/fasteners/technical/proper.htm
Response Posted - 03/03/2008 :  21:19:01  Show Profile  Visit britinusa's Homepage
Here's a trick you can use to ease the spliting of FB when driving a screw into a pilot hole:
Use a dremmel with a disc cutter (they are about 1/32" thick) to cut a grove along the thread from the screw tip towards the head of the screw, but not going all the way to the screw head.
It will act like a self tapping screw and drastically reduce the tendency of the screw to crack it's way into the fiberglass.
lewalskim
Response Posted - 03/04/2008 :  06:29:18  Show Profile
What size would I use to drill a hole in the mast in order to tap it for a #10 machine screw? What about a #8?
welshoff
Response Posted - 03/05/2008 :  13:29:10  Show Profile
I bought a small drill/tap kit that included the drill bit to go with each tap. Takes the thought process out of tapping for fasteners.
sterngucker
Response Posted - 03/05/2008 :  16:19:25  Show Profile
Here is a handy web site for determining tap and clearance holes.
http://www.marfas.com/machinescrewtapping.shtml
Enjoy!
Al
Response Posted - 03/05/2008 :  19:45:08  Show Profile
I'm no expert, but I don't think you'd want to tap a thread into material as thin as I assume our masts are. To make up for the thinness of the material, you need thread depth and I think the thread depth of a sheet metal screw is much deeper than even a coarse thread machine screw in an equivalent size.
I've only heard of using sheet metal screws or rivets on a mast...
