 Working with Starboard question?
Scooter
Initially Posted - 03/03/2008 :  20:00:38  Show Profile
This is the first time working with Starboard. Two questions:
1. What sealant have people used to seal it to the bulkhead and/or other surfaces (or gel-coat)? The package lists a "glue" or sealant to use but does regular 4200 or other types work too?
2. Is there anything you can do to stop the "shedding" it does where you cut it? I am trying to make a round cover and it sheds like spun fiberglass. Heat/melt it?
Scooter
C25 '89 SR/WK #5878 "Square Knot"
Vandemere NC.
Response Posted - 03/03/2008 :  20:12:01  Show Profile
I believe you can use 4200 or 5200 for sealing but the piece must be mechanically attached (screws). No regular adhesive will work. From the Starboard web site:
"StarBoard can not be glued using standard adhesives. Products like 3M's 5200 work well as a water sealing caulk but will not adhere StarBoard to itself or other materials in a permanent bond."
Andy_334
Response Posted - 03/03/2008 :  21:53:09  Show Profile
Oops. My bad. I thought this was a rules-of-the-road question.
Carry on.....
tmhansen
Response Posted - 03/03/2008 :  23:35:48  Show Profile  Visit tmhansen's Homepage
I have not had it shed like you describe. It makes a snowy white mess of my shop. What are you using to cut it. I have cut it with my table saw and then run it through the router. All I needed to do after was a little finish sanding of the edges.
Response Posted - 03/04/2008 :  06:06:41  Show Profile  Visit OLarryR's Homepage
I used a scroll saw to cut a round cover as part of my fishfinder project. The Starboard round cover was bolted over the depthfinder hole to a Starboard support board inside the cabin used also for mounting the RAM Swing Arm for the fishfinder. Below is a photo of the round cover. My website has other photos including the inside mounting board. I ahve also use the Starboard as a mounting board between the transom and the outboard motor bracket. In these installations, 3m 4200 was used more as a sealant than anything else. Bolting is what really secures the Starboard.
I have used a radial arm saw with a blade for cutting soft/plastic type matls to make straight cuts. The white stuff does fly off quite a bit. But the best saw for shape cutting is using a scroll saw. That is what i used to make the round cover and and the mounting board. I bought the scroll sqaw at Sears. if not familiar with a scroll saw, it has a small platform of about 8-10" wide/circular and it uses a small, thin blade similar to that used in a hand held saws but the scroll saw's motor moves the blade up and down to make the cuts. You can adjust the speed of the saw. It makes a lot less mess and it cuts shapes very well since the blade allows the work to be turned as you do the cutting. I then beveled the edge of the shaped boards using a router bit on my accessory side of my radial arm saw.
Edited by - OLarryR on 03/04/2008 06:08:14
Scooter
Response Posted - 03/04/2008 :  08:08:55  Show Profile
I cut it as close to the round shape I could then drilled a hole in the center. I mounted it on my grinder then "turned" it like on a lathe. I used files to rough cut it then finer and finer sand paper. It allowed me to cut down the inside edge to create a lip so the plate would then sit centered "inside" the bulkhead hole. Then I beveled the outside edge. I just need to take it to my father Inlaw's drill press to cut the 2" hole for the depth sounder.
I'm thinking of starting over though. If I cut a larger and deeper center hole I can maybe get the depth sounder to sit "embedded" into the piece a little. Then a standard instrument cover from the old knotmeter would cover the plate and the depth sounder. I beveled the this one too much so the old instrument cover won't catch the edge of the new plate.
Response Posted - 03/05/2008 :  22:01:12  Show Profile
I agree with everyone above... Cut it to rough shape, and then use rasps, sanders, hand-sanding, or any other wood tools--it works like very hard Ivory Soap. But too much speed with electic tools can cause melting, which generally isn't desirable.
