 Delamination around cabin windows
rafort
Initially Posted - 03/09/2008 :  18:13:12  Show Profile
The cabin interior has separated from the cabin exterior around the bottom a window. A previous owner tried to fill the area with a caulk. I removed the window, separated the parts, cleaned and dug out the caulk. It appears Catalina used an amber rubbery adhesive to make an bond then filled the gap with a filler. Does anyone have a suggestion for re-bonding and filling the two fiberglass parts? With the window out they can be easily pulled together with clamps.
Response Posted - 03/09/2008 :  18:39:51  Show Profile
When I removed my windows, there too was a gap which is probably quite normal and not a sign of the cabin interior separating from the exterior, but rather the way these boats were built.
rafort
Response Posted - 03/09/2008 :  18:53:50  Show Profile
I forgot to mention my boat is an 86 that does not use the aluminum frames to mount the windows.
