 how fast can a cat 25 swing go
quilombo
Initially Posted - 03/16/2008 :  19:42:38  Show Profile
just wondering , in full combate regalia, how fast can a catalina 25 swing go, with an experienced helmsman at the tiller
with the right wind of course,, any war stories out there,
Response Posted - 03/16/2008 :  20:20:24  Show Profile
Hull speed equals:
1.34 x (sq. root of lwl) or <b>6.31knots</b>
http://home.golden.net/~capone1/wsc/calc.htm
So, in theory, your boat can go no faster than hull speed. That is, the speed that the the displacement hull can move water out of the way and move forward.
Having said all that, somebody here will tell tales of going faster than hull speed.
Response Posted - 03/16/2008 :  21:52:32  Show Profile
&gt;"tell tales of going faster than hull speed."
Remember that the hull speed equation is an approximation. Bottom line is that your best (only?) shot at exceeding 6.some-odd knots in a C25 is getting a push from a following sea.
Response Posted - 03/16/2008 :  21:57:39  Show Profile
First, theoretical hull speed is just that. Actual hull form can allow some variations, but it applies pretty well to a C-25. That's the speed at which, to go any faster, a boat has to climb up over its bow wave, which generally a sailboat doesn't have enough power to do. The most common time that it does is when gravity is helping--on the front side of a wave ("surfing") before the wind. C-25's have gotten into the 8+ knot area in that situation. You can tell you're exceeding hull-speed when spray starts coming off the hull admidships. You've probably had fun going much faster in a powerboat, but when you get a sailboat surfing, there's hardly any greater rush!
Response Posted - 03/16/2008 :  23:06:51  Show Profile
I've hit 10.4k on a beam reach (verified by another boat alongside (an O'day 28)who had an accurate knotmeter. I've also hit 9.5k going downwind with a poled-out 155%. Both of 'em were quite a rush!...
Justin
Response Posted - 03/17/2008 :  07:28:32  Show Profile  Visit Justin's Homepage
I've had my GPS show holding mid-high sevens, maxed at 7.8 knots over ground last fall during an awesome sail on the Chesapeake Bay. We were surfing with the waves and it was a blast!
Response Posted - 03/17/2008 :  07:51:03  Show Profile
I've done 8.4kts under headsail alone. Keep in mind the LWL increases with heel.
Response Posted - 03/17/2008 :  15:23:25  Show Profile
...a tiny bit... The C-25 doesn't have much overhang.
JimB517
Response Posted - 03/17/2008 :  15:31:25  Show Profile  Visit JimB517's Homepage
I've seen high max speeds like thy've said. You can easily reach 7.5 knots when there are big waves and strong wind - its fun!
On the other hand your trip planning should assume a speed of 5 to 5.5 knots under power and 4.5 knots under sail. Yes you can hit the mid sixes or higher. You won't be averaging that over any distance. You won't want to power up the outboard to push you at 6.3 knots either - it burns a lot of gas. Cruising along at 5 knots is a very comfortable and economical RPM - 12 minutes per mile. I get about 15 to 20 mpg at this speed.
When you are under sail and on a cruise trying to get somewhere and speeds drop below about 3 knots (its different for everyone) time to start motorsailing.
JimB517
Response Posted - 03/17/2008 :  15:32:12  Show Profile  Visit JimB517's Homepage
oh and thank God for all the questions from Quilombo, without you this board would be dead right now!
Ben
Response Posted - 03/17/2008 :  15:34:19  Show Profile
I was on a beam reach during a race once and got the boat (according to the GPS) up to 6.7 knots. I sail on a small reservoir, so there was no current or tide to account for this. At the time I posted on this site the phenomenon, because it struck me as incredible, but someone explained it adequately (not that I remember the explanation).
Response Posted - 03/17/2008 :  15:51:13  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Ben</i>
<br />I was on a beam reach during a race once and got the boat (according to the GPS) up to 6.7 knots. I sail on a small reservoir, so there was no current or tide to account for this. At the time I posted on this site the phenomenon, because it struck me as incredible, but someone explained it adequately (not that I remember the explanation).
A. Hull speed is a theoretical, calculated number, your actual milage may vary.
B. The calculation goes up as you heel since, as Don pointed out, the LWL increases with heeling.
esailor
Response Posted - 03/17/2008 :  16:39:48  Show Profile
Don't know about the c25 but I have water skied behind an Escow.
Pete
Response Posted - 03/17/2008 :  21:25:31  Show Profile
Planing hulls are another world, especially rockets like scows
Response Posted - 03/19/2008 :  12:46:14  Show Profile  Visit aeckhart's Homepage
Wind approx 15 knots. Waves approx 3.5 ft. Sails, main and asymetric spinnaker. Speed 11.2 knots. Absolutely the most awesome sailing experience in 19 years of sailing a C25.
Edited by - aeckhart on 03/19/2008 12:50:54
Response Posted - 03/19/2008 :  13:30:22  Show Profile
At the rate the speeds are going up, we'll be racing Maxi's next week.
Response Posted - 03/19/2008 :  13:43:17  Show Profile  Visit Prospector's Homepage
There is always the factor of whether you measure speed on GPS (over ground), or on your instruments (relative to the current) being pushed along at 6 knots by the wind with a 6 knot current helping could get you up to 12 knots on GPS, but only 6 knots on the instruments.
Then there is the difference between speed and velocity made good, which factors in leeway and efficiency in your course.
Seems nothing is simple in sailing...
2far2drive
Response Posted - 03/20/2008 :  12:14:15  Show Profile  Visit 2far2drive's Homepage
Ive hit 6.7 on GPS. best avg over 10 minutes was 6.3
Ive been watching a lot of racing lately, what does 20+ feel like&gt;????
anyone seen the video of the French attempt to beat the record for sail driven vessel?
http://youtube.com/watch?v=xFJocBvj-_w
Response Posted - 03/20/2008 :  12:26:33  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by 2far2drive</i>
<br />...what does 20+ feel like&gt;????<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Edited by - Dave Bristle on 03/20/2008 12:31:27
Response Posted - 03/20/2008 :  13:09:01  Show Profile
<br />Ive hit 6.7 on GPS. best avg over 10 minutes was 6.3
47.6 knots -- pretty slow for an airplane. Wonder why they couldn't rotate and fly? That thing only vaguely resembled a sailboat. Looked more like a poorly designed airplane. If I ever need to go that fast, I'll go for a ride on Bristle's stinkpot.
Response Posted - 03/20/2008 :  14:14:44  Show Profile
Sorry John--I can't quite get to 40... but 47.6 is pretty good for an "airplane" with no engine and not diving!
stampeder
Response Posted - 03/20/2008 :  16:52:12  Show Profile
Hey Dave, Sarge looks pretty good with those C25 handrails.
Response Posted - 03/20/2008 :  21:05:50  Show Profile
Thanx! There's even a pair under the hardtop--you can't see them in the pic. All done with Cetol Natural Teak. Almost like being a rag-bagger again!
