when I bought my boat it came with the autopilot electric gyro thing, that connects to the tiller, I dont quite remember the brand, but Im sure you guys know what Im talking about, its like an electric gyro with a motor which actuates a ram rod to attach to the tiller, seems iike its more trouble to use than its worth, I was in West Marine and I bought this tiller tamer device any input on this , what do you all think of this thing , Ive seen it used a few times
I think your opinion regarding the confusion with the "autopilot" might be due to your lack of knowledge about it. Let us know what model it is and we can instruct you on how to use it properly. Autopilots open up a whole differnet world then a tiller tamer.
Joe's right... A tiller-tamer, or other method of fixing the tiller, can hold your course for a minute or less before the boat wanders, due to seas, wind changes, or simple geometry. The tiller-pilot (or "autopilot") will hold a course indefinitely (except in difficult conditions like large following seas). If you daysail in limited venues, the pilot might not be worth the setup, and the hee-haw noises might be annoying. But if you cruise any distance in open water with little traffic, being able to attend to other things (like your bladder) while the helm attends to itself is wonderful!
I'll second what Joe and Dave said about the autopilot. A tiller tamer isn't even a close cheap imitation when it comes to tending the tiller. I say if you already have the autopilot, give it a go before installing the tiller tamer. If you're like most, you'll return that tiller tamer post-haste. I'd return it anyway and use a bungee setup instead. Nothing to install and you probably have the bungee onboard already.
Aren't Auot tiller's prone to stripping gears though? I think I remember reading this someplace. Would it be a good idea to have a tamer on hand as a backup?
I used a tiller tamer that came with my boat for several months before installing my ST1000 autopilot. It's like the others have said, the tamer is OK for a very short while, but the autopilot is really a whole different deal, especially when alone and a problem comes up that requires you attention during unusual weather. I would not consider not having it now, having had a few issues during a blow alone. If you tell us what type it is, I am sure someone here (probably not me, but one of the people here with tons of experience) can help you get it set up and working. They really are great.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Prospector</i> <br />Aren't Auot tiller's prone to stripping gears though? I think I remember reading this someplace. Would it be a good idea to have a tamer on hand as a backup? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">As long as you understand it won't really do the job. The better backup is you.
I have a tiller tamer and as all have said it is only a temporary device for holding the tiller in place. Winds, waves and other factors can extend or shorten its usefulness. In fact, I am replacing my old tiller with a new one since I am refinishing my rudder. I am not planning to move the tiller tamer to the new tiller, just use a bungee cord between lazarettes.
And if I really have to leave the tiller for a minute or two... I turn it over to the Admiral.
I also had a tiller tamer. It's good for what it is but by the end of a 3 day sail I was bruised up and pretty tired because of all the running (and running in to things in my haste) I had to do. I recently bought a simrad tp22 and fell like I've been delivered from evil!
I have heard of people stripping the gears and the consensus was it was due to overdriving the gears at the end of the travel. I know my Raymarine Autohelm model does not have a cutoff switch to engage when it reachs full extension or retraction. So it continues to try and push/pull the worm gear which is tough on the nylon components. Special attention should be made to avoid overdriving the gears.
Joe, what would "overdrive" them--changing the course 120 degrees all at once? I vaguely recall that some models (perhaps the ST2000?) protect against something like that, while some don't.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Bristle</i> <br />Joe, what would "overdrive" them...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Hitting the +/-10 button too many times Initiating/Accepting a large course change when in track mode. Having the main sheet snag the ramrod, lifting it from the pin. Autotacking Too much weatherhelm Excessive following seas
There are probably a bunch more that aren't coming to mind right now...
Also: Letting the boat drift in calm conditions while the auto-tiller is trying to steer a course. Removing the pilot from the tiller pin and forgetting to place the pilot in standby mode.
Quilombo, Follow this link to the online owners manual for the Autohelm 1000. Basically, you need 12 volts for power and them point your boat in the direction you want to go and hit "Auto". You can then adjust your heading using the "1" and "10" buttons to turn an appropriate amount of degree from your "Auto" heading. If you can provide us with the problems you are encountering we can advise further.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DaveR</i> <br />I also had a tiller tamer. It's good for what it is but by the end of a 3 day sail I was bruised up and pretty tired because of all the running (and running in to things in my haste) I had to do. I recently bought a simrad tp22 and fell like I've been delivered from evil! <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
