I have purchased a Rule Industries thru-hull fitting to install in the transom for the electric start cable from motor to battery. The threaded portion is 1 1/4" outside diameter and the closest fitting hole saw I have is 1 1/2". Should I use it and be more liberal with caulking the new hole opening, or get a smaller hole saw? Pros and cons, anyone?
DavidP 1975 C-22 SK #5459 "Shadowfax" Fleet 52 PO of 1984 C-25 SK/TR #4142 "Recess" Percy Priest Yacht Club, Hamilton Creek Marina, Nashville, TN
I installed a Marinco 30 amp twist lock trolling motor plug on my transom for my electric start Honda. I just have to remove plug when I take the engine off. Very convenient. Has plenty of capacity for the starter. I keep dielectric grease on the plug.
And I did buy the correct size hole saw for it. Lowes has a good selection of cheap Chinese saws.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Lowes has a good selection of cheap Chinese saws.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
The Dalai Lama and I are boycotting all things Chinese. Hole saws of that size are not that expensive, even the ones made in North America.
Thru-hull fitting $10, trolling motor plug set was interesting but not at $45. Got a less expensive source, Frank? Trying to save the extra $. Concensus seems to be to get the smaller size hole saw. Also, I wanted the thru-hull in case I decided later to upgrade to a remote for the new o/b. Thanks all for the feedback.
I used a trolling motor connectors but ran them in through a boot protected opening high on the transom. All the electrical plugs are in the storage compartment protected from moisture but easily access for disconnection. The fuel lines from both tanks plus the engine controls and wiring also run through the same opening. All are wrapped with sun protected cloth tied with black plastic ties.
David, I have been looking for a thru-hull for my starter cable and the new solar panel cable. Had not thought of using a 'pipe' fitting.
Currently (ugly) the starter cable passes though a 'hole' in the rounddown stbd side with 'goop' for water proofing (never got the area wet so really can't say if it's a 'dry' arrangement.)
I found a compression thru-hull in the new West Marine Catalog pg. 434 'Wire Seal'. I think that would make a much better seal than a thru-hull pipe fitting. Also look at the CeaCap Conduit Bulkhead passthru although it's not designed for watertight uses.
Frank, I've perused your web site. Clearly you take great care of your boats. Let's just chalk this up to how fast those lazarette drain channels can get dirty!
